Old 07-09-2009, 04:14 PM   #1
Orange52
Orange52's Avatar
MII or S10 frame swap for AD truck?
I can't make up my mind. Keep going back and forth trying to decide which way is the better way to go. Each has its pro's and con's. I have both. Ie I have my original frame with an MII crossmember installed (then slightly butchered by me, but nothing a competent fabricator couldn't fix. ie not me), I also have a std cab longbed S10 frame with v8 installed and cab mounts created using plans from Jeff51.
I want a truck that I can reliably drive across the country if I want to. I've read some bad things about MII's tearing the I bolts through the upper A arm mounts, and the fact that special bearings are needed to run the GM rotors isn't something I like.
On the other hand, I don't like the idea of running spacers in the front if I go with the S10 frame.
I'd have this thing done by now if I could just make a decision and stick with it!
Ok, throw your opinions my way! Which is better?
Orange52 is offline   Reply With Quote
Old 07-09-2009, 04:39 PM   #2
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Re: MII or S10 frame swap for AD truck?
The spacers for the S-10 are perfectly fine if your not planning on taking it off road. They will hold up. You could also get a deeper back space on your wheels. Someone correct me if I'm wrong though.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 07-10-2009, 08:58 PM   #3
iokua80
iokua80's Avatar
I've done the s10 swap. I like the s10 swap as far being really low and still being able to turn. I'm not running spacers on mine. It works for me.
Later,
Josh
iokua80 is offline   Reply With Quote
Old 07-10-2009, 10:15 PM   #4
mylow53
mylow53's Avatar
i'm a fan of the m2. i prefer to use the original frame. i haven't done a s10 swap so i can't say it's easy or hard. but i did the m2 wasn't that hard it was everything else that was hard. and yes get a pro do do your welding. suspension installations are not the place to practice your welding...
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 07-10-2009, 10:51 PM   #5
Thadious
Did the S10 swap myself and same issues with the spacers... currently running 2 1/2" ones just for layup, but will be mocking up and building a tubular set, probably from chromoly tubing in the future.
Will post them when I do.
Cheers,
Ted.
'51 Chevy Build - In the design stages
Aut viam inveniam aut faciam - I will either find a way or make one.
If you don't have time to do it right the first time, when will you...
My new build - https://67-72chevytrucks.com/vboard/...70#post8958970
Thadious is offline   Reply With Quote
Old 07-10-2009, 11:50 PM   #6
54 jimmy
54 jimmy's Avatar
i don't have any spacers on the front of mine. i don't plan on putting any on. without spacers with stock s10 wheels it gives you a tucked look which i like. i am also running the stock 2wd rear axle with 10 inch wide mags and the backspaceing on the is the same as the stock wheels so it brings the back wheels out to where they need to be. take a look at my build pics and you'll see. the only thing is when i get my box put together i will need a little mini tub in it no big deal.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 07-10-2009, 11:54 PM   #7
jeffs51chevy
jeffs51chevy's Avatar
For me it was the availibility of the s10 frame and other major components that I already had on hand. I have 15 x 8 cragars with a 2 1/2 back spacing. They fill out the wheel well nicely. I won't run spacers at all. If reliability is what you are going for, the s10 is about as reliable as you are going to find. Not to mention parts are in every town you will roll through. How'd the mounts work. I hope they are working for others and not just me.
Thanks,
Jeff
jeffs51chevy is offline   Reply With Quote
Old 07-11-2009, 08:11 AM   #8
Orange52
Orange52's Avatar
Jeff, I've got the front cab mounts temporarily bolted in place, I think they'll work great. Now I just need to decide if that's the best way for me to go.
