12-16-2008, 02:01 PM | #1 |
Building Dreams out of Dimes!
Looking for a particular size tire and rim...
My truck is dropped 2.5" front/4" back using spindles and hangers/shackles.
I want a wheel and tire combo that isn't ALL Wheel (20s) or ALL tire (15s) Right now my truck has an equal amount of wheel and tire but see that big huge gap in between the tire and the fender well? That just doesn't look good to me. I want the tire stop right at the fenderwell. Well what do you think? What size wheels and tires should I get? Trying to keep it custom but stay classic. |
12-16-2008, 04:10 PM | #2 |
Re: Looking for a particular size tire and rim...
try a 17 or 18 in wheel and a 50 series tire. If thats not what you have on it already, but it looks like a 16....
12-16-2008, 05:24 PM | #3 |
Parts and more parts
Look at a 17" by 8" rim for the front of the truck with a tire around a 255/50/17 to 275/50/17 size. Those are 27" and 28" tall tires for reference. The back can be a 17" by 9" rim with a 275/50/17 or 285/50/17" tire (28" and 28.3" tires)and that would work out quite well.
12-16-2008, 06:32 PM | #4 | |
I'm looking at keeping my 15's and going to a 275/60 (28" tall) but then again I like the 'big tire' look since I have a stock height. |
12-16-2008, 07:10 PM | #5 |
What do you have on there now, 50 series tires? I bet if you go with a 60 series, maybe a 255/60 front and 275/60 rear, you will be impressed, and you won't have to buy new rims (unless you want to).
A 60 series tire on your 15'' wheel is by no means an "ALL TIRE" look. Plenty of rim still stands out. |
12-16-2008, 09:07 PM | #6 |
laying low
Have you tried using one of the wheel visualizers available online from the wheel companies to see what size wheel and tire you would prefer?
Have a look at this one. http://www.newstalgiawheel.com/wheel_visualizer.asp You click to see different type, style and size wheels and tires on many different types of vehicles with stock ride height, dropped and different paint colors to get a better idea of what your ride will look like. It might help you. Using this viewer I think your truck will look good with a Cragar SS in 16x7 or 16x8 with a 275/60 tire and your present drop. JMO I went up to the post a pic of your ride thread and there are several pages of good looking trucks with all kinds of styles and size wheels and tires and I picked this one as what I thought was close to the look you are looking for. Fellow member Classic 87 with 17x8 and 17x9.5 wheels with 255/60 and 275/60 tires. Check em out.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross Last edited by Boog; 12-16-2008 at 09:41 PM. |
12-16-2008, 09:26 PM | #7 |
I agree, 275/60/15 would be a great size. I think that BFGoodrich Radial T/A's look best in that size.
1977 GMC Sierra Grande |
12-17-2008, 01:03 AM | #8 |
Insert Witty Text Here
255/70/15 on 15X8 wheels and dropped 2.5/4 if it helps any...
Slonaker Last edited by Slonaker; 12-17-2008 at 01:04 AM. |
12-17-2008, 02:14 AM | #9 |
6.0 powered square
you could go lower,a 6-8 would have the front tires almost tuck in the front and the back would be
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 12-17-2008 at 03:35 PM. |
12-17-2008, 05:43 PM | #10 | |
Why would braking ability suffer? The height of the tire is what changes your braking aspect, not the wheel size. The 275/60/15 tire is the same diameter as the 275/50/17, the difference is the sidewall exposed. The exposure of your brakes is easy to control with dust shields (Front and back wheels) and they can be purchased just about anywhere. Besides that, you could paint the disc brake caliper and make them stand out, rather than hide them. |
12-17-2008, 06:14 PM | #11 | |
12-17-2008, 06:22 PM | #12 |
225/55/17 in front...........275/55/17 in rear
" Never look up a dead dogs butt." |
12-17-2008, 06:51 PM | #13 |
Believe me the rotational mass of the 17" aluminum wheels, on my truck is much less than the rotational mass of the steel 15" wheels that were on it before. Granted the mass is approximatel a 1" radius further out, the weight of the wheel is so much more less and the affect is so minimal that you would not see it. However, you slap a larger tire on that 15" wheel and the weight of the rubber becomes paramount in your calculation of the mass and it will amaze you with the result. That is why the guys with monster mudder tires on their 4X4s cannot stop. This is basically an insignificant item in these sizes. My DD just went from the 17" tires and rims to the old 15" tires and rims for winter and the stopping has not changed in any appreciable amount.
12-18-2008, 10:01 AM | #14 |
Yes I am in agreement with you about a larger tire having a negative effect on braking.
But, even if the 17" wheel weights the same as the 15" wheel, its all about where there weight is. Moving that weight out 2" makes it harder for the same brake setup to stop that, thus a larger diameter wheel will have a negative effect on braking. Also, putting dust shields behind the wheels to hide the brakes might only make it worse as it would restrict any airflow that's essential to cool the brakes. |
12-18-2008, 04:23 PM | #15 |
Cruzzzn' Vet
275/50/15 tires on 15x9 rims, 4/5 Drop
12-18-2008, 05:31 PM | #16 | |
OK with me---however, it works with my setup and I have it on two different years of trucks and I have had no issues. Good Luck |
12-18-2008, 06:20 PM | #17 |
Here are a couple of mine . Front is lowered with 2.5inch spindles and 1 inch coils. Rear is lowered with 4 inch drop leafs and another inch using shackles . Front rims are 17x8 with 4.5"backspace and a 255/55/17 tire at 28 inches tall . Rear is a 17x10 with 4.5" backspace and a 275/60/17 tire at 30" in height .
Born and proudly residing in a Red State ! |
12-18-2008, 06:30 PM | #18 |
This is the tan truck I sold in August . It was lowered 2.5/4 and running 18 inch wheels with the same tire sizes as on my black truck .
Frank
12-18-2008, 07:11 PM | #19 | |
