03-01-2004, 12:27 PM | #1 |
Bolt Pattern/Wheel Help! (4x4)
I need a new set of wheels for my truck, but don't know the proper backspacing or bolt pattern. I have a 1985 GMC Sierra 4x4 1/2 ton. I know the wheels are 6 lug, but I just want to confirm that they are 6x5.5. Also...what backspacing do I need? Brakes are all factory...discs up front & drums in the back. Any help would be great.
Thanks, Josh |
03-01-2004, 12:42 PM | #2 |
I do know that they are 6 on 5.5, but someone else will have to help with the back spacing.
Chris '92 ext. cab s/b 4.3L "Sparky" '04 crew cab 2500 4x4 6.0L |
10-15-2007, 11:01 AM | #3 |
Re: Bolt Pattern/Wheel Help! (4x4)
Bringing this back from the dead. I have an 84, so practically the same. What is the center hole size? What should backspacing be? Thanks
Matt |
10-17-2007, 03:29 PM | #4 |
No one?
10-17-2007, 05:58 PM | #5 |
It is a 6- 5.5 bolt spacing, usually when buying rims it'll say for chevy truck. Because the center flange has to be bigger to accomidate the hub assembly
As for backspacing....no clue Duro
-1986 K10 LWB, 350 HD,TH400 3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires All original, second owner truck -1979 Monte Carlo, 350, 200r4, 3.73 posi -1987 GT T-top Mustang - slow moving project |
10-17-2007, 06:37 PM | #6 |
I believe the backspacing on a 6 lug 5.5 is 5". ...Joe
I'm not speedin'! I'm qualifyin'! |
10-18-2007, 09:48 AM | #7 |
Thanks!!
10-18-2007, 10:52 AM | #8 |
www.73-87chevytrucks.com
AFAIK all factory Chevy truck rims use a 4" backspacing regardless of rim size (7 or 8" wide)
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
10-18-2007, 06:08 PM | #9 |
I believe that he was asking about aftermarket rims. At least that is the way that I understood the question. I'm running aftermarket wheels on both of my trucks. One has 16x8s and the other has 15x10s. Both have a 5" backspace. Hope this helps. ...Joe
