10-05-2024, 11:48 AM | #1 |
nylock vs. lock washer...which is best?
Kinda surprising results... https://www.youtube.com/watch?v=pDZ8PezMzzY What if you use both at the same time... https://www.youtube.com/watch?v=Iao2HT71kB8 -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
10-05-2024, 12:18 PM | #2 |
Who Changed This?
Re: nylock vs. lock washer...which is best?
Not surprising that the lock washer case came loose. The washer wasn't completely compressed. He should have done this test with the recommended torque of 31 Ft-Lbs for this type fastener.
10-05-2024, 12:48 PM | #3 |
Agreed...more torque would have definitely made a difference. The video is far more interesting at 6lbs though! Another issue that stands out is...those nylock nuts I've dealt with required more than 6lbs just to turn so trying to torque them down at such a low value seems inaccurate at best. -Kevin
10-05-2024, 12:56 PM | #4 |
I actually posted that as a comment in the video when I first saw it. It's impossible to test a fastener's holding power unless it's properly torqued.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
10-05-2024, 01:57 PM | #5 | |
Who Changed This?
10-05-2024, 04:32 PM | #6 |
On my hot rod projects I use grade 8 bolts and grade 8 nylocks. One of the reasons I use nylocks is that when you use a washer it doesn't crack the paint or powder coat. Never had one come loose.
10-06-2024, 07:28 AM | #7 |
I am sort of a redneck and grew up on a farm. Each type of bolt has it's rightful place to be used. If a nylock gets hot it's not going to hold the same. I like lock bolts but they bugger the threads after the first use. I use lock washers if I run out of nylock bolts and can't get to the store. I used to take a standard bolt and put it on a vise and bang it with a hammer to make it slightly out of round and boom-lock bolt. I have always wondered how a lock washer on top of a standard washer holds with a standard bolt.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
10-06-2024, 03:47 PM | #8 |
Post Whore
Caterpillar machinery quit using lock washers many decades ago. They use grade 8 fasteners and under every nut or bolt head, there is a hardened flat washer. Some fasteners are required to have Loctite.
If you ever have an opportunity to buy a junk Cat engine for cheap, do it the as fasteners are some of the best around.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-06-2024, 06:54 PM | #9 | |
I wonder if he's tested torque nuts? Bet they beat nylon/split washer to )_&_&+, though been wrong before.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
10-06-2024, 08:46 PM | #10 |
Who Changed This?
OK, I had to go look that up. I've seen those used on truly ancient MOPAR products, like my dad's '51 Dodge truck- "ancient" meaning that that truck was one year older than I. Dodge Bros did things a bit differently, like left hand threads on the left side of the vehicle. They may have worked better, I have no idea. I note that cotter pins are far more common now, and MOPAR has gone to all right hand threads(?).
10-07-2024, 11:44 AM | #11 |
Moot point and a waste of a video and everybodys time if the fastener was not torqued to specs
10-07-2024, 05:51 PM | #12 |
Red loctite .
10-08-2024, 07:47 AM | #13 |
Wedge Lock washers have been our go to around the shop in recent months.
https://www.nord-lock.com/nord-lock/products/washers/
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
10-09-2024, 09:13 PM | #14 |
Split washers, also known as lock washers, are useless as a locking feature. Don't believe me? Ask NASA: they do NOT allow split washers on anything. Period.
ALL fasteners are torqued to a given spec and then it's either a mechanical locking features such as a poly-loc nut, safety wire, or distorted nuts OR chemical thread locking compounds such as Loc-Tite. Oftentimes it's multiple features. This applies to ALL fasteners. NASA publication RP-1228, pp. 9-10 |
10-09-2024, 09:43 PM | #15 |
Post Whore
Hard to beat a good crossthread....
10-10-2024, 06:24 AM | #16 | |
Those were my thoughts as well. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-10-2024, 06:53 AM | #17 |
Old guy at the gas station I started at "cross thread is better than lock-tite"
10-10-2024, 07:23 AM | #18 |
laying low
^^^ Hands down!
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
10-10-2024, 10:33 AM | #19 | |
Who Changed This?
10-15-2024, 10:59 AM | #20 | |
Its a Truck Thing......
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
