04-05-2002, 12:02 AM | #1 |
finished my 6cyl to 8 cyl swap (pics)
Got my 350 engine put in the truck. Boy does it run good. I am really happy with the way it turned out. Now I just got to clean up the sheetmetal to make it look better. Just thought I'd share.
------------------ 67 3/4 ton progect 68 chevy swb stepside Sparks NV
68 short fleet with 71 front clip 2wd jaguar blue 99 chevy ext cab shrtbed z71 loaded 99 chevy swb fleetside(daily driver) Sparks, Nevada |
04-05-2002, 12:10 AM | #2 |
Very nicely done.......69 longhorn.
http://community.webshots.com/user/hotrodhorn |
04-05-2002, 12:17 AM | #3 |
Member since 2000
that looks great, what the stats on it, what kind of tranny are you running
------------------ Mechanic @ California Concept Britney: 1970 2wd K/5 Blazer (Frame up) Jessica: 1967 2wd SWB (pops daily driver) Helga: 1972 4x4 3/4ton LWB (my daily driver) AIM:Alexmart1 Mountain View, Cali |
04-05-2002, 12:22 AM | #4 |
The block is a standard bore, Nothing special. the heads are 305 heads that I did a valve job on and new springs and such. With 305 heads on the 350 block I am running about 10&1/2 to 1 compression ratio. I did a compression test on it today. The tranny is a turbo 350. I'll probably put in a b&m shift improver kit in it as soon as I recover from the cost of putting in the engine. Thanks for the comments.
04-05-2002, 08:42 AM | #5 |
Semper Fidelis
It looks great. Is that shroud from a 4x4? It looks deep in the pic, and with the long pump how far is the fan in the shroud?
72 Chevy C 20 with 402 For sale 85 GMC K2500 83 Trans Am Cedar City, Utah (Missouri Native) |
04-05-2002, 08:52 AM | #6 |
Very nice job. I will be doing the same change over in the next couple months. That looks to be mounted in the I6 position , right? Was there anything extra you had to add besides the new X-member for the tranny?
------------------ 72 C/10 LWB 2wd 250 inline 6, 3 speed column shift. Soon to have a total facelift.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
04-05-2002, 10:21 AM | #7 |
Did the cross member bolt holes line up?
69 SWB C/10 5-6 drop 700R4 69 Firebird Convert 455 4 spd 70 Torino GT Convert Austin-Texas |
04-05-2002, 08:39 PM | #8 |
Thanks for all the comments Guys.
robby: Actually the fan shroud is out of a big block truck. I need a longer shroud due to mounting it in the I6 position.The fan is in the shroud about 3 or 4 inches. It worked great. dubie: Yes the engine is in the I6 position. I put it there so that I could use the same driveline.With the 350 turbo shorttail shaft I didn't have to have a new driveline made.Thats right all I neede was the transmission crossmember. Frank_Zeller: The bottom holes lined up but the top didn't. I thought I'd drill those out when I put on my new cab. I hope this helps, And again Thanks for the comments. Jim ------------------ 67 3/4 ton progect 68 chevy swb stepside Sparks NV
