Old 03-12-2012, 08:03 PM   #1
Vern E
Headers
65 chev fleetside, Iam dropping in a 350 chev, do the shorties work better or are the longs a better install?
Vern E is offline   Reply With Quote
Old 03-12-2012, 08:20 PM   #2
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Re: Headers
I bought hookers ( headers that is ) and they slipped right into place without issue.
GMR-PERFORMANCE is offline   Reply With Quote
Old 03-13-2012, 01:13 AM   #3
Captainfab
60-66 Nut
Re: Headers
The long tubes are better for street performance. Are you running an auto trans or a manual? There are long tubes that will fit just fine. Hedman #69090 and Hooker #2452's. The Hedman #69260's are designed to fit these trucks with a small block.
Old 03-13-2012, 02:04 AM   #4
blackedoutharley
Re: Headers
Be aware that the Hooker 2452's and Hedman #69090 have 1 5/8" primary tubes but the Hooker's have thicker flanges & 2.5" collectors vs. the Hedman having 3" collectors.
The Hedman #69260 have 1.5" primary tubes..
Somebody smarter than me will be able to explain the differences in pipe sizes to you.
blackedoutharley is offline   Reply With Quote
Old 03-13-2012, 11:06 AM   #5
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Headers
I have a 61 fleet with a 305 and shortys. They have 2.5" flanges and they work great. I dont know the brand, they came with the truck.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-13-2012, 11:14 AM   #6
ozzyman
ozzyman's Avatar
Re: Headers
I have hookers(long) on my 66 327 v8 and I had to slightly modify my clutch linkage to clear the headers(manual trans), it just required a slight bend is all which was in the install instructions
ozzyman is offline   Reply With Quote
Old 03-13-2012, 11:51 AM   #7
Vern E
Re: Headers
I guess I should have given all the info, I will be installing a 350 TH tranny with the 350 motor. I do appreciate all the replys, thanks
Old 03-13-2012, 12:37 PM   #8
losthope
losthope's Avatar
Re: Headers
I have headman longtubes with a 350/350 setup work great
But they hang down below the frame and im lowering quite a bit so im gettimg something shorter
So depending on if your gonna lower your truck or not length may or
may not be a factor to look at
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
