Old 09-04-2013, 02:31 PM   #1
Larry64
3 speed manual trans
1964 short step 230 I6. I having am having shifting problems. Truck was popping out of 3rd gear. As I am trying to adjust the linkage. Now for the dilemma, with all the linkage off I can get the 2-3 shifter fork to move, but not the 1-R even with the 2-3 in neutral. Any idea what I have done to cause this?
Thanks Larry
Larry64 is offline   Reply With Quote
Old 09-04-2013, 02:51 PM   #2
1963c-10
1963c-10's Avatar
Re: 3 speed manual trans
1st gear in non-synchronized in the factory trans if you still have the mc318. If you shift from 3rd into neutral....it should allow you to manually shift it into 1st.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 09-04-2013, 04:31 PM   #3
Larry64
Thank you again. That worked along with someone pressing on the clutch.
Larry
Old 09-04-2013, 04:56 PM   #4
1963c-10
1963c-10's Avatar
No problem....glad you got it resolved.
Old 09-05-2013, 10:41 AM   #5
MikeN
MikeN's Avatar
I had a problem with my original 3-speed manual popping out of 3rd. Unfortunately, I don't think it's a linkage problem. I think it basically means the transmission is worn out, and needs to be rebuilt or replaced.
MikeN is offline   Reply With Quote
Old 09-05-2013, 11:10 AM   #6
1963c-10
1963c-10's Avatar
I have a spare mc318 sitting in the shed if it helps any....
Old 09-05-2013, 07:32 PM   #7
Larry64
Thanks, but I have a 92 Camaro T5 that I put a manual speedo s-10 tail shaft on that is going in soon.
Larry
