Old 03-25-2007, 02:54 PM   #1
ChadMorris
Newbie truck Rebuilder!
Wheel tub work
I have 2 wheel tubs in fair shape. When you work them back out, I know I can't get them completely smooth.
Do most people use bondo or filler on the curved part?
That seems like a bad place to do that...
just curious, as I need to start work on getting my bed in shape to put back on..
Chad
"Old Blue" 1964 GMC Fleetside in pieces
350 TPI with 700R4 tranny now installed( well kinda propped in place until the tranny crossmember is bolted in !!!!!
1995 Toyota 4runner , 197,000 miles and going...
2007 Honda Odyssey Van (Wifes car)
ChadMorris is offline   Reply With Quote
Old 03-25-2007, 10:04 PM   #2
glennhuff
Re: Wheel tub work
If you are planning on using the bed to haul stuff, then bondo probably wouldn't be a good idea. However if you are going to use the bed to haul stuff, then a little bit of wavy in the wheel tubs is no big deal. You should be able to straighten the tubs out enough to make them look good with no bondo. It's just a lot of work. Good luck.
Glenn
glennhuff is offline   Reply With Quote
Old 06-02-2007, 01:42 PM   #3
LILRED66
LILRED66's Avatar
Re: Wheel tub work
With the wheel tubs off the truck, you can easily work out most every dent with a body hammer and dolly. Metal bumping is not real difficult, however it does take some care and expertise in order to avoid stretching the metal. In the case of wheel tubs, the factory sheet metal is a heavier gauge steel and less liable to stretch. You can work most dents out well enough to avoid application of body filler.
LILRED66 is offline   Reply With Quote
