04-19-2004, 12:27 PM | #1 |
Drum to disk? 71 to 67
Will the front disk set-up from a 713/4-ton bolt up to a 673/4-ton with out changing the cross member?
04-20-2004, 11:32 PM | #2 |
TTT
04-20-2004, 11:52 PM | #3 |
Fabricate till you "puke"
you can swap the brakes without the crossmember. You will need to use the 71 upper & lower balljoint assys to bolt the spindles on, & may run into steering stop issues with the 67 lower arms(shortened steer radius). Try to get all the pcs from the 71.....tierods ,center link ,ect, & you will be ahead of the game, as all of those pcs differ from the 67-70s, as compaired to the 71up trucks. oN THE 3/4 TON, you should find the same balljoints & tierods from 71 to about 86. Yoiu will also need a master cyl for the disc brake truck. Good luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
04-21-2004, 10:14 AM | #4 |
Thanks Crazy,
