Blazer top rattles....any tips?
my Blazer is missing the strip on the tailgate will this clear up most of the rattle?Any tricks you guys use or just live with it?it has new seals everywhere
Thanks Al |
SKINNY TIRES RULE!
Re: Blazer top rattles....any tips?
You can adjust the hatch brackets a bit. There are the pieces that create tension against the hatch when it is latched closed. If you move them out a bit so they create more pressure, it will help reduce rattles. You might also try to put a piece of thick foam weather stripping on the bottom of the hatch where it meats the tail gate.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
![]() ![]() Join Date: Jan 2002
Turn the radio up or where ear plugs.
![]() ![]() 1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
I'm not exactly sure I'm picturing the problem but I've found that some rattles can be fixed by taking some extra tubing, cutting a half inch square (or what ever size works best) and using that as a wedge or temporary 'seal' to stop rattling and protect whatever the rattling object is hitting..
2001 silverado stolen by family 1983 short n wide custom deluxe SOLD 1985 silverado longbed 305 engine 700r4 OH NO! NOT ANOTHER LEARNING EXPERIENCE!!! "Just because you can do it, doesn't mean that you should" |
SKINNY TIRES RULE!
I know what the problem is.
There are a series of bolts that run along both bedsides and 4 in the windshield frame. Remove them. Remove the top. Rattles will be gone so long as you do not reverse these steps. ![]() Last edited by SeventyOne; 03-04-2011 at 06:48 PM. |
![]() Join Date: Apr 2004
the best thing you can do is take it off and never put it back on. That's what I did.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#8 | |
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
I agree with the exhaust fix, cherry bombs or louder magnaflows!
Thanks for the help guys.Living on the Wet Coast taking the top off isnt a option if I want to drive the thing more than 3 months of the year. I went to NAPA and got some adhevise foam tape and that got 95 % of it.That and adjusting the latchs(thanks for that tip bouncytruck)Cant wait to go topless though.Hey bouncytruck were fairly close when do you start going topless?
Later Al |
#11 | |
SKINNY TIRES RULE!
