What type of socket do I need here?
Re: What type of socket do I need here?
All you need is a twelve point socket. Most bolts you see will be six point. That is six flats with six points to drive off. However there are also twelve points that have twelve points to drive off. These will not fit in a six point socket correctly.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
[QUOTE=In The Ten Ring;6255271]what sort of socket do I need here?
QUOTE] Those are 12 point flange head bolts. Any 12 point socket will work. |
7/16s. Also, most combo box & opened end wrenches are 12 point on the box end.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Most box wrenches are??? CHECKING RIGHT NOW!
Thanks a ton guys! |
channel locks
Old member
Don't use channel locks if at all possible. Only as a last resort. Correct tool for the correct application. 12 point socket are box end.
U can change them out though once u get them out. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Please don't use Channel Locks. You can buy a cheap wrench anywhere for under 5 bucks. Just look for a box end that's 12 point, which is a majority of them.
Posted via Mobile Device |
Oh no, I know better than to bugger up a bolt by using the wrong tool. I used the box wrench and they came off just like the man said. BUT it seems my core support is pretty rusty.....I will join the site as a paying member so I can put out a want ad for a rust-free core support.
I'd rather stay with OEM if possible since I fear a repo won't fit quite right. |
#10 | |
Old member
![]() Quote:
