05-09-2024, 09:41 AM | #1 |
landarts
Re: Super Cheyenne aka the "Devil Cowboy"
Been working on getting all the areas with filler sealed off and scratches from sandpaper filled. Little by little the old Devil Cowboy is starting to come around. Was able to get the corner of the cab by the gas tank looking good and both rocker areas. Had one area on the other corner that showed up after a light coat of primer.
Also a couple of weeks ago I was able to pick up the TH350 transmission and the NP205 that were rebuilt by a local shop. Need to find out how to tackle the sheared of front axle splines. I have never done that repair, so I will be digging into the research and getting parts ordered when I get that figured out. Pic 1 - Drivers rocker Pic 2 - Passenger Rocker Pic 3 - Cab corner Pic 4 - Rebuilt transmission and transfer case Pic 5 -Sheard off axle shaft inner and outer damaged
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
