Old 07-08-2010, 07:17 PM   #1
Mr. Potato head
1982 gmc AC r12
Hi i have a 1982 gmc and need the ac to work , i search the forums search tab no items ,, My question how to convert to the 134a oil from the r12 , i did some googeling , . Somone here must have done it , thankyou
Mr. Potato head is offline   Reply With Quote
Old 07-08-2010, 07:54 PM   #2
77gmcjoe
What do we get for $10?
77gmcjoe's Avatar
Re: 1982 gmc AC r12
I took my '77 to a garage that I trust and had them do it. I figured it was safer to let a professional do that.
1977 GMC K25 400/400/205
1989 Chevy Suburban R1500 350/700R4 (work beater)
1994 Chevy K3500 dually 454/4L80
1996 Corvette LT4 350/ZF 6 speed
2000 Bonneville SSEI Supercharged 3.8 Liter V6
1966 Chevelle 2 door sedan (Needs major repair )
77gmcjoe is offline   Reply With Quote
Old 07-08-2010, 08:26 PM   #3
Skratch
Skratch's Avatar
Re: 1982 gmc AC r12
This is in a nut shell . . . every line has to be broken loose and cleaned internally with the proper cleaning products, every o-ring has to be replaced, once the system is reassembled the accumulator has to be replaced as does the orifice tube and new adapters added to the high and low side ports, then the new oil (normally Esther oil in a R12 to r134a conversion) is added to the system (some to the compressor itself and some to the high side), the system is vacuumed down to remove all air and moisture, the new refrigerant in now added . . .
Unless you have experience doing this work and the proper tools to pull the vacuum, then I really recommend having a qualified shop do the work, even if they let you supply the parts.
I did all the work to mine, cleaning, o-rings, new oil . . . then let Sears pull the vacuum and recharge . . . they destroyed my system because they didn't pull any vacuum and added even more oil then overcharged . . . don't take your truck to Sears, those guys are friggen idiots!
Yes you can do it at home, yes some people do it without pulling a vacuum, in the end the system lasts a much shorter time.
If you want it to last and work well, find a good shop and talk to them about options to keep costs down like supplying your own parts.
If it ain't broke, then I haven't fixed it yet!
'86 Fiero SE 2M6 (undergoing a Northstar swap)
'87 1/2t 4wd Suburban (4" lift with built 1t axles and beadlocks)
'90 3/4t 2wd Suburban (Tow Rig)
'94 3/4t 4wd G20 Van (Toasted tranny and rusted)
'96 Deville
Skratch is offline   Reply With Quote
Old 07-12-2010, 01:28 PM   #4
Jeepwm69
Re: 1982 gmc AC r12
You can get a vacuum pump on autozones loaner tool program to pull a vacuum on your system. FYI
Jeepwm69 is offline   Reply With Quote
Old 07-12-2010, 01:39 PM   #5
Skratch
Skratch's Avatar
Re: 1982 gmc AC r12
Dang it, I rent tools from there all the time and I didn't know about that . . . well I guess there is next time then.
Thanks for the heads up.
'96 Deville
Old 07-12-2010, 05:07 PM   #6
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: 1982 gmc AC r12
My R-12 all leaked out so i bought 3 cans of Dura-Cool and put it in after I fixed all the leaks. Works very well I must say for a DIY
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 07-12-2010, 06:22 PM   #7
Mr. Potato head
Re: 1982 gmc AC r12
Thanks , i read some on google about welfare fix with propane lol , boom ill look into the Dura-Cool thing .
