10-29-2017, 11:22 AM | #1 |
Heater Core
Anybody know where is the best place to buy a heater core for my 63 C10 at a affordable price? Thanks Marc....
10-29-2017, 12:45 PM | #2 |
Re: Heater Core
I would try rockauto.com they list both styles and usually arrive in just a few days.
10-29-2017, 01:10 PM | #3 |
Re: Heater Core
I got mine from Rock Auto, about $45 if the remember correctly.
http://s1299.photobucket.com/user/jb...23904108567829 |
10-29-2017, 03:09 PM | #4 |
Re: Heater Core
Local radiator shop. Because using the side tanks from original will most likely be end result. There are other wright ups here on how "replacement" dosnt fit.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
10-29-2017, 03:32 PM | #5 |
Re: Heater Core
pro-tip: prior to installing any heater core, especially aftermarket, reman, or repair where new manufacture is not available, pressure test prior to install for insurance.
good luck! |
10-29-2017, 11:08 PM | #6 |
60-66 Nut
Re: Heater Core
That depends on which heater you have. Do you have the recirculating heater or the Deluxe heater? If you have a deluxe heater with a working Ranco valve, you will have to have the tan ks switch at a radiator shop no matter which heater core you get. You can get one for a '64-'66 Deluxe heater since you are going to change the tanks. The core for the recirculating heater is easy to come by.
10-31-2017, 10:14 PM | #7 |
Re: Heater Core
The best way to do it is get yours rebuilt.
10-31-2017, 10:43 PM | #8 |
Re: Heater Core
Thanks for all the tips... I bought one from O'reilly's they are local and it's pretty darn close to what I took out..... My old one was 54 years old and I could get it repaired but I was afariad there might be some thin spots in the metal that would start leaking down the road....
