Old 03-14-2012, 02:00 AM   #1
lmdangerous
How much vaccum is needed for my wipers to work.
I have a 1951 JS code 1 ton pickup. I am in the process of cleaning the wiper motor up and getting as much as i possibly can out of the factory wipers. The motor is a 235 (1957) and it has some wear, but it holds 18 lbs of steady vaccum, other than when you stab the pedal. I know the electric set up is the way to go, but I would rather stay with the vaccum wipers. That would be one less thing to worry about on the electrical system .
LMD
lmdangerous is offline   Reply With Quote
Old 03-14-2012, 01:21 PM   #2
OrrieG
OrrieG's Avatar
Re: How much vaccum is needed for my wipers to work.
16-18# is fine, but when you open the throttle the wipers will pause, pain on long hills or passing. I grew up driving these trucks in western Oregon in the 60's, got real good at letting up for a couple of swipes on the hills. The old trucks had them mounted exposed above the windshield with a lever so you could over ride them manually! I once had a motor go bad and the girlfriend got to use a hanger attached to the arm with her arm hanging out the passenger window on the trip back from the coast. Funny now, I think she left me for someone that had a newer car....
OrrieG is offline   Reply With Quote
Old 03-14-2012, 06:47 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
get something like this and put it under the dash.
http://www.ecstuning.com/BMW-E90-335...ngine/ES26343/
it helps with the lag issue.
dwcsr is offline   Reply With Quote
Old 03-25-2012, 05:43 PM   #4
lmdangerous
I just got through rebuilding/ cleaning , so far very good. They actually are really fast- as fast as the previous electric wipers that we put on my 55 some time back. . Question am i suppose to be able to control the speed by the switch setting -- Cause mine does.depending on where I set the switch -i get a slower or faster speed - My 55 from years back had only one speed .
I also replaced all of the bushings in the wiper arms and trans with polymer type bushings / and really cleaned,oiled , and polished the shafts .
I have not gotten the reserve canister yet- but I will.
LMD.
Old 03-25-2012, 07:19 PM   #5
G&R's57GMC
G&R's57GMC's Avatar
Do you have one of these ?
G&R's57GMC is offline   Reply With Quote
Old 03-25-2012, 11:11 PM   #6
lmdangerous
Not yet , I think the old AC # was AC6603, but the Airtex #is 4666 for the 261 (1963 model) the airtex, and ac 6603 is actually for the 230-292 ,but they will all interchnge.And I intend on swapping in a 250/200r 4 combo . Has anyone used one along with the wipers - I assume it makes them work even better???
Old 03-25-2012, 11:21 PM   #7
messy jesse
i have a 58 napco and my wipers suck hella slow hahaha
messy jesse is offline   Reply With Quote
