Old 09-01-2013, 03:16 PM   #1
sblackmon
Engine Hesitates and Dies
Bought a 68 C10 LWB with a 396. It ran a little rough when I got it and tried to tune the carb (old q-jet) and found that it had a large vacuum leak. The truck did run and drive ok though. I replaced the q-jet with a 1406 Edlebrock and got it tuned in good. Now when I drive it hesitates and dies when I accelerate. It does better if I punch the gas. When it is parked it idles great and I can hit the gas then (in park) and no problem. Any ideas?
sblackmon is offline   Reply With Quote
Old 09-01-2013, 05:23 PM   #2
SCHRUMGMC
SCHRUMGMC's Avatar
Re: Engine Hesitates and Dies
When I press my Pedal mine dies as well
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 09-01-2013, 05:59 PM   #3
sblackmon
More info. When I adjusted the idle mixture I got the vacuum gauge to change (rpm change) when I went lean, but never got a change when I went rich. Gauge showed good vacuum all the way out. It also has an electric fuel pump. I is reading about 7 psi. Edlebrock states no more than 6. Not sure if that would cause the hesitation and death.
Old 09-01-2013, 06:03 PM   #4
SCHRUMGMC
SCHRUMGMC's Avatar
How much does one of them Electric Fuel pumps run ?
1971 GMC Sierra
1959 GMC 100
Old 09-01-2013, 06:59 PM   #5
FLDBRED
How long has the gas been in the truck?
FLDBRED is offline   Reply With Quote
Old 09-01-2013, 07:19 PM   #6
sblackmon
Not sure the cost of the pump. It was on the truck when I bought it. The gas is fresh. I actually ran it out of gas a few weeks ago while I was working on it. So I know the stuff in it now is good.
Old 09-01-2013, 08:22 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Does it have the points style distributor?
Does the vacuum advance work?
Have you checked the fuel filter?
How old are the plug/coil wires?
There are a lot of things that can cause the issue you relate.Give us a few more details and maybe we can better guide you.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-01-2013, 08:44 PM   #8
SCHRUMGMC
SCHRUMGMC's Avatar
Question does a 1971 gmc have points and if so were would they be located ?
1971 GMC Sierra
1959 GMC 100
Old 09-01-2013, 09:50 PM   #9
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
It sure does buddy, the points are under the distributor cap. The cap is what the spark plug wires plug into behind the air cleaner.
--Josh
Old 09-01-2013, 10:08 PM   #10
SCHRUMGMC
SCHRUMGMC's Avatar
Thanks man, that could be a reason it isn't starting up correctly...Hmmm
1971 GMC Sierra
1959 GMC 100
Old 09-03-2013, 09:15 AM   #11
sblackmon
It is a point style distributor and the vacuum advance works. The plugs and coil are fairly new. I have not changed either of the fuel filters.
