Need AM radio wiring harness
I just bought a radio wiring harness for my radio online and all it is is a single red wire with a connector on each end (the power wire). I thought it was supposed to be a 3 wire deal... power/neg. speaker/pos. speaker with the factory black 3 spiggot connector on the radio side. Can someone straighten me, out or does anyone have the correct wiring harness I need. I'd like to use the factory one and don't want to start mickey mousing things. Thanks Doug
I will try to make it out to my parts truck today and see if it is there and in good condition. I took an AM radio out of it, so I would ASSume it is. I will let you know.
Yours for shipping cost, if it is good to go. Squid
'69 C10 LWB- 305, Holley 2 barrel, 700R4, 4/5 drop, dark blue primer!, cheap driver project... Back on the road... In time to sell on Ebay. ![]() |
#3 | |
Bloo
there are three wires, but the red wire is all there is to the actual radio harness... the other two go to the speaker, and they share a ground. if you notice in the pic, the speaker wires have an empty hole, this is where you red wire plugs in
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
-Squid4life. Thanks! If the speaker connector is cut off its still what I will need (as I'm using a different 10 ohm speaker anyway and already have the plug end for the new speaker)
-Blue71. Thanks abunch for the pics! They explained everything. |
Squid, did you happen to check and see if you have the wire harness yet? Just wondering, if you don't have it thats cool also... I'll start hunting for one again. Thanks Doug
Sorry, was out of state for my sons Dr.'s appt. I looked at it on the parts truck before we left but the mice had tore it up pretty bad. The one I had thought was good was for the heater controls. Sorry about that.
Squid
No problem Squid, thanks for looking anyway. Regards Doug
