Old 12-17-2011, 02:01 PM   #1
i heart square bodys
i heart square bodys's Avatar
side exhaust routing
I have an 86 long-box Chevy, I wanted to bring the exhaust out at a 45 degree angle in front on the rear wheels on each side, I have found that this is a problem because of the gas tank location. I have seen this done before and I was wondering how it was done . also just wondering if its possible to have both pipes come out the side opposite of the gas tank and still remain true duals. thanks to anyone that can help me out !
i heart square bodys is offline   Reply With Quote
Old 12-17-2011, 02:43 PM   #2
Pop's C-10
Pop's C-10's Avatar
Re: side exhaust routing
Tha tank shouldn't be a issue aslong as they is enuff air space between tha tank
& the pipe. yes you can run both down one side & still be dual. it would take mounting tha mufflers on there side next to each other &some good skills with a pipe bender.
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 12-17-2011, 09:13 PM   #3
almighty awesome ! thanks for the tip , I'm still a little sketched out by having the pipe that close to the tank but I guess if its done right I shouldn't need to worry much , maybe make a heat shield if that's what I decide to do
Old 12-18-2011, 12:01 PM   #4
bmchevy1979
bmchevy1979's Avatar
does the exhaust have to come out at a 45 degree angle if not you could do it more like this in pic
this is how mine on my 76 is done just not in stainless
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 12-18-2011, 01:46 PM   #5
76stepside
76stepside's Avatar
Exhaust should be at least 3" from gas tank... if closer then it needs to be shielded!
8.1l 496 4l80e
76stepside is offline   Reply With Quote
