Old 10-21-2014, 09:42 AM   #1
hdff
hdff's Avatar
rear end factory option
does anyone know what the most common rear end from the factory was on a c10 with a 402 big block. i am assuming either a 3.73 or a 4.11.
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 10-21-2014, 10:07 AM   #2
turp mcspray
turp mcspray's Avatar
Re: rear end factory option
It believe it was 3.07.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 10-21-2014, 10:53 AM   #3
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
1/2 T + BBC = 3.54 Dana 60 much of the time.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 10-21-2014, 11:07 AM   #4
hdff
hdff's Avatar
what i do know about mine is it doesn't have a dana by looking at the bolt pattern
"Wanda"
Old 10-21-2014, 11:40 AM   #5
turp mcspray
I think the big block 1/2 tons only used a dana, if it had a stick. Autos used the 12 bolt.
Turp Mcspray
Old 10-21-2014, 01:42 PM   #6
68Gold/white
My 68 396 (TH400) is a 12 bolt 3.07....
68Gold/white is offline   Reply With Quote
Old 10-21-2014, 08:51 PM   #7
Mike C
Mike C's Avatar
I'm with the other guys. Most 1/2 ton big block trucks will be 3.07. Most 3/4 ton trucks will be 3.54 Dana 60.
The semi-float 60 with 6 lugs was pretty uncommon and I don't think is found after '69?
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-21-2014, 09:09 PM   #8
engineer_gregh
engineer_gregh's Avatar
According to the GM Heritage doc the standard offering was 3.07 for the 402 engine. At least for the 1971 model. See page 18.
File Type: pdf 1971-Chevrolet-Truck GM Heritage Center Page 19.pdf (63.4 KB, 85 views)
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 10-21-2014, 09:44 PM   #9
hdff
hdff's Avatar
thanks for the info greg. I am just waiting for a week day off to take her to a rear end shop for repair and find out what is in there. I am considering going back with either a 3.73.or a 4.11 with a posi. hopefully a couple of more weeks and then a weekday off. here is the rear end and from what I have found this is not a dana rear end. I don't know why it is uploading upside down in my file it is not
"Wanda"
Old 10-21-2014, 10:47 PM   #10
da-burb
"Ochre Ogre"
da-burb's Avatar
I second Mike C on the C10 vs C20 BBC rear gears.
hdff, You have a 12 bolt in your picture.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 10-22-2014, 09:00 AM   #11
Big Block C/20 automatics got Dana 60/3.54s and C/10 automatic got 12-bolt/3.08s
Old 10-22-2014, 10:22 AM   #12
engineer_gregh
Here is the link for the complete document. If you go with a 4.11 I believe you would have to change the complete rear housing. I've seen 3.73 gears that will fit into the 3 series carriers now. Maybe some of the more experienced guys can chime in once you know what you have currently.
https://www.gmheritagecenter.com/doc...olet-Truck.pdf
Greg Smyrna TN
Old 10-22-2014, 11:09 AM   #13
69 MOD
69 MOD's Avatar
If you want to quick check it at home so you have a close idea of your ratio here's how:
Place a mark on the top of your tire, and a mark on your driveshaft (chalk/grease pen/marker)
Block your front tires so the truck can't roll, jack up the rear end.
Rotate the tire and watch the driveshaft, at 1 full revolution of the tire the mark on the driveshaft will have turned "X" amount of times.
This number will be your ratio
Example: 3 1/2 rotations of the driveshaft would most likely be 3.54 gears, just over 3 rotations = 3.07 etc.
Just a quick way to find the ratio without fully disassembling the rear end...
MOD
Chad
'71 GMC 2500 Custom Ol Blue
'72 Custom Deluxe Highlander Stuffed Olive
'73 Trans Am
'13 Silverado 2500 Duramax Storm Trooper
69 MOD is offline   Reply With Quote
