Old 05-17-2004, 12:07 AM   #1
stan79chevy
stan79chevy's Avatar
what kind of transmission is it?
its a 3 speed manual that came stock in my 77 3/4 ton parts truck. its hooked to a 205 transfer case. its a "3 on the tree" i was thinking about maybe putting it in my truck or selling it but dont know what it is. will the adapter thats on it work for a sm465. when i looked up info about a 205 transfer case it only talks about 3 different versions th350, th400 and the sm465. i have the original rpo sticker out of the glove box if that can help identify it.
any help would be appreciated thanks
stan
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 05-17-2004, 01:01 AM   #2
Truckstuff
Truckstuff's Avatar
Heres a start. The only 3spd on the tree in a 4x4 that I have had, came in a 72 Jimmy.
If I remember right (long time ago) the transfer case was a dana 20 and the adapter was part of the t-case. The whole set up was totally different than the 465/adapter/205 that I put in. Yes, the RPO might help.
Real Trucks are Built not Bought
Building: 1981 GM SB LowRider
1985 GM K3500 3+3
1981 GM K2500 SSB
1980 GM K2500 X-BC Hydro
1979 GM K3500 3+3
1976 GM K5 Blazer
1970 Custom 10
http://bc4x4.com/
Truckstuff is offline   Reply With Quote
Old 05-17-2004, 01:28 AM   #3
687980chevy
687980chevy's Avatar
The 3 sp. adapter is different than a sm465 adapter.I helped a friend years ago put a 4sp.in his 77 1/2 ton.It came with a NP205.He used the trans cover from the other truck also.I don't remember it being to bad of a swap.
But the 4sp. has to be a 4x4 trans.>tailshaft different on a 2wd.
68 K-10,79 K-10,80 C-30
57 chevy convertible
79 Z28
687980chevy is offline   Reply With Quote
Old 05-17-2004, 01:34 AM   #4
1969 GMC
1969 GMC's Avatar
I would venture a stab at the SM330...at least that is what 67-72 4x4's with a 3 on the tree used. I have heard about that combo in a 73-87 before, but I'd never seen it. One good thing is that the NP205 was the only transfer that came with one of these.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-23-2004, 10:38 PM   #5
stan79chevy
its definately a 205 transfer case
i crawled under there today and it still has the tag on it and says the transfer case is a 205. i had my brother in law look at it and he has no idea.
i have a picture of the glove box sticker but earthlink isnt letting me get to the ftp uploader thing right now
the option number is 1mc1 and under sescription it says 271m15 3-speed manual
4.56 gears rock
LWB pimer black
4.3/4L60E/233
Old 05-26-2004, 01:36 AM   #6
stan79chevy
i crawled uder there today and got some pics and found some numbers on the transmission
280L35 3
E0376
thats the only numbers on it i can find
it has the shifting linkages the drivers side not on the top
stan
4.56 gears rock
LWB pimer black
4.3/4L60E/233
