Truck is embarassingly slow
I have a 72 C20 w/ a 350. since I bought it i have opened up the exhaust a little and put a quadrajet on it. The people who had it before me put a turbo 350 in it, i do not know what the rear end is. I assume 4:10, but it is geared very low. I run out of gear at about 60mph. I am getting about 9mpg which i assume is the powervalve on the quadrajet, but yesterday while checking my 0-60 time it was 17s! And the truck topped out at about 78 after a good 30 seconds of hammering it! Could this be my gearing causing all of this? I have a 3spd manual w/ a granny gear I am considering putting in it, but unless this has any substantial gain to offer i do not want to waste my time on this truck. Being geared so low I would have thought it's acceleration would be great, but it sucks. Another thing I was considering was a new torque converter. A few months ago when i put a new turbo 350 in it my torque converter i got with it smelled burned up, then when i got it together it whined real bad for about 2 weeks and then it quit whining. Now it slips here and there when i take off at a stop sign, I probably should have switched that out a long time ago but i didnt think anything of it. So, if anybody has any suggestions on what to do to my truck please let me know.
its all about the +6 inches
Re: Truck is embarassingly slow
your trans sounds like it is about to crap out on you. Assuming the level is good, then it will be going sooner rather than later. The burned smell you described also points to an experation date rapidly aproaching.
Your trans may be slipping bad enough to be hurting our 0 to 60 time, you could have a worn out motor, and you may be expecting too much out of a heavy nonaerodynamic truck. I've neverr driven one of these with an old stock 350 and felt it was fast by any means. I doubt your gearing his holding you back on 0 to 60. It'll hold you back on the top end, but it should be able to hit 100 with no problem regardless of engine or tranny options. The fact that you are maxed out at 78 MPH tells me you are either running a worn motor/slipping tranny... or, more likely, you are afraid to run it past 3800 RPM. |
I have a 307/sm465 with a 4.56 rear end im pretty sure and its not fast but it will get up and go when i want it to. Sounds like you need a new tranny, id say go with a manual but if you want to hammer on it all the time and jam through the grears id get a m22(i think thats what the camaros had in them im sure somebody will corect me if im wrong) instead of your granny tranny you want to put in it because there ment more for racing and the shift ratios are a lot better for your 0 to 60 time.
1969 Chevy c20(Miss Hackjob) |
Active Member
![]() Join Date: Jul 2007
I wonder if they converted from a manual to auto or six to v8. I did that on my old 69 with a 4.10 and had a similar problem with it reving extremely high at highway speeds. It had plenty of power on the takeoff but sounded like it was going to explode in the higher speeds.
I changed to a 3.08 and it solved my problem. MPG was about 15 on the highway and 10-13 in town. |
M21 or M20 would be alot cheaper to comeby and MAJORLY LESS ANNOYING than a M22. 700r4 is the way that i would go!
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
![]() Join Date: Feb 2011
I have the same setup as you and my truck runs like a raped ape. The 4.10 gears should make it faster, not slower (up to about 120mph). I don't know if it is your tranny, but something is seriously wrong. I would start with the simple stuff before jumping to the transmission, fuel filter, pump, timing, bad valve. Have you checked your compression?
1971 C20 Longhorn Custom Camper |
My 3/4t 4wd with 350/TH350,3.54s,and 12.50/33 tires,and posi catches 2nd when I floor it off the line. If it ad 4.10s it would even be quicker and catch 2nd more. I had a 2wd 3/4t as described above except 4.10s and another 4wd the same way and both were quicker. I'd run 75-80 down the interstate,too. I love that sound.
#8 | |
![]() Thanks
M20 has a deep first gear (wide ratio) M21 and M22 have the same gear ratios but the M22 has straight cut gears and that causes them to whine unbearably! all M22s are also fine spline and take the same yoke as a th400. late model M21s (70-74) share the same fine spline shafts too!
#10 | |
It had 3:73 gears, that would spin the tires with a stock 350. After I went to a 3:08 gearing, it was embarrasingly slow. A SLUG to be exact.
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" Last edited by wwotr; 02-27-2011 at 08:07 PM. |
Plain and simple you have 4.56 or 5.13 gears. the power valve sounds fine and if the trans was on its way out the fuel mileage would would be far worse, like 5 or 6 mpg. I have a 70 half ton with 3.08 gears and when the trany went south I got about 6 or 7 mpg. if you get bigger tires or change the rear end gears it will get better but right now you could pull your house off its foundation!
![]() ![]() ![]() 67 c10 swb build in progress 70 c10 lwb driver pending parts for drastic overhaul 70 c20 lwb parts truck for above mentioned drastic overhaul 71 k20 lwb building for off road use and towing |
#12 | |
![]() ![]() ![]() 67 c10 swb build in progress 70 c10 lwb driver pending parts for drastic overhaul 70 c20 lwb parts truck for above mentioned drastic overhaul 71 k20 lwb building for off road use and towing Last edited by maynardtruckin; 02-27-2011 at 09:36 PM. |
#13 |
True, 4.10 is a little too much. My truck will almost never use first gear.
#14 |
fast does not equal quick
quick does not equal fast Fast is a high MPH Quick is the amount of time to get to said MPH A 3.07 gear will be faster than a 4.10 gear all other variables being equal. a 4.10 gear will be quicker than the 3.07 gear, again, all other variables being equal. |
#15 | |
Cops, ha, catch me if you can!
72 C-10 Stepper 350/TH350 3.73 in the back Edelbrock intake and Carb Hooker Comp Headers 275/60R15 on Rallies ![]() ![]() |
#16 |
Big Red - Now its a SWB!
I agree with longhorn man about quick vs fast. That said your 4.10's should be great for 0-60 runs, if your in the 17's to get to 60 you have a problem. You need to hit all the basics before you jump into swapping trannys (although yours does sound like its not in the greatest shape).
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
#17 |
I've also heard somewhere, maybe even here, dunno been a while but thought it was am amusing. "Rpm is how fast you hit the wall, Torque is how far you make the wall move" i might have butchered that
"Feel it's not a bonfire unless they can see it from space?" ~ Capt. Morgan 1970 Cst - 20 402 1984 Chevy C30 6.2L Diesel crew cab Dualie |
#18 |
3.07 for velocity
4.10 for acceleration so whats the best gear for jerk force? ...thats not an insult, jerk is a unit of measure. ....it is the measure of force that throws your head into the rear window when you hit the gas.
#19 |
the boat guy
jerk force sounds alot like centrifugal force and the easter bunny. No such thing. Your head isn't being thrown back when you hit the gas, the truck is accelerating, pushing your body foreward and since a body at rest stays at rest uuntil acted upon by an outside force it feels like your head is being thrown back but in reality your head wants to continue to stay going the same speed.
so the QUICKER the truck accelerates the more force the trucks seat applies to your body pushing it foreward..... Unless you're in reverse when hitting the gas. |
#20 |
#21 |
yep.
#22 | |
Active Member
![]() Surprisingly enough, I had no problems with lack of power and for my purpose, which was farm work, it was fine. I towed a MF135 tractor with a 6 foot bushhog and a boxblade all in an 18' trailer for 150 miles and it towed really well. |
#23 |
on my 402 when i had problems with it "falling on its face" like it did the exact thing... my secondaries wernt opening up on my 4 barrel.. so i fixed that.. then came to find out my points were shot.. so i replaced it with an autozone accel hei distributor, coil, plugs and wires and it fixed the problem
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
#24 |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Sounds like to me youve got a truck that needs alot of corrective tuning! I would drain and inspect all the fluids from the crankcase to the rearend! Take a look at the modulator valve and its vacuum supply. Inspect and change the plugs(spark) that will tell volumes of info on engine health and carb tune. You indicated "opening the exhaust" a bit, how? Ill bet it was quicker with a bbl on it. Ill bet that Q-Jet is either dumping more fuel into the ol girl than she can handle or that its so far out of tune that a draft nags going to out run it no matter what the trans and ratios are. Raise the rear axle and count the rotations of the drive shaft to one full turn of the wheel to get your rearend ratio. Slightly over 3 turns is 3:08, slightly over 4-1/2 turns is 4:56. Me? Id stick with 350turbo(if its still good)and changing fluid and filters in them tranny's with a new modulator valve works wonders,(if) the fluid indicates a somewhat healthy tranny.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#25 |
http://en.wikipedia.org/wiki/Jerk_(physics)
The derivative of velocity is acceleration, the derivative of acceleration is jerk, physics 101.
