Old 03-12-2013, 04:54 PM   #1
jorgensensc
jorgensensc's Avatar
Need quick help identifying electric fan.
Sorry for the dire sound, but I found an electric fan on Craigslist for 50.00. Guy says it is a 2 speed mark7 fan. Pulled it out of a 97 Lincoln. I'm confused because it has a white plug and 3 wires, red, blue, black. I thought all the two speeds had 4 wires and a black connector. Should I buy this or not? Is it the right 2 speed fan? I need a high and low since I have ac. I've read some used variable voltage to control the fan, is this one of those? Im suppose to go get it in 2 hours. Thanks for the last minute help!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
