Old 04-11-2010, 09:31 PM   #1
72_cheyenne
72_cheyenne's Avatar
Question HEAT or CUT Coil Springs??
I have a budget till july so i wont be able to buy my ECE 4/6 drop kit anytime soon...does anyone know how i could mess around with the stock springs till then?
Red Chevy's
72_cheyenne is offline   Reply With Quote
Old 04-11-2010, 09:53 PM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: HEAT or CUT Coil Springs??
cut one loop off the front and put a set of J body springs ( or jeep tj) in the rear .....done...
Hottrucks is offline   Reply With Quote
Old 04-11-2010, 09:54 PM   #3
Security guy
Security guy's Avatar
I'm sure you'll get alot of replies on this subject, but my opinion is to never heat the springs. I've cut 1 coil and sometimes 1 1/2 coils off. I think each coil equals about a 2" drop. Get new drop springs when you can afford it though.
Security guy is offline   Reply With Quote
Old 04-11-2010, 09:56 PM   #4
71swb4x4
71swb4x4's Avatar
Another vote for cut, not heat. Heat can really mess with the ride.
The rear you can't cut, but you can do 2" lowering blocks back there for cheap.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-11-2010, 10:30 PM   #5
72_cheyenne
Thanks alot guys,,my dad also said to cut if anything lol but how much loops should i cut for a 4/6 drop. or how should these springs measure afterwards?
Red Chevy's
Old 04-11-2010, 10:44 PM   #6
fjthompsoniii
If you have heavy duty front springs ie if you cant put a 3/4 inch wrench over the wire 1 1/4 coils is max without problems. if they are the light ones ie 3/4 wrench will fit over wire 1 1/2 is max you can cut without problems. Cant cut rear. Take shocks off and use heat but dont heat the center of spring. lay the spring down on it self at the bottom, if that makes sense. allow for rear to settle.
fjthompsoniii is offline   Reply With Quote
Old 04-12-2010, 12:41 AM   #7
Ackattack
Ackattack's Avatar
I don't think you're going to get a 4/6 drop with just cutting springs without running into problems.
For cheap, I'd cut 1 coil off the front and put a 2 inch block in the back, that will give you about a 2/2 drop for very little $$
Ackattack is offline   Reply With Quote
Old 04-12-2010, 06:48 AM   #8
Hottrucks
Hottrucks's Avatar
guess I made it to easy....................or maybe a set of UNHEATED stock tj springs from the bone yard ($10) was to much
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Old 04-12-2010, 07:45 AM   #9
cdowns
cdowns's Avatar
bewbest way i've found to cut springs is with a cutoff wheel
its best to start by cutting 1/2coil and see how you like it then if you need more cut somemore// once cut you cant glue them back
Old 04-12-2010, 08:23 AM   #10
robzilla
robzilla's Avatar
any particular years? how much drop do you get with these springs?
robzilla is offline   Reply With Quote
Old 04-12-2010, 08:48 AM   #11
Hottrucks
Hottrucks's Avatar
4/4 or so do a search this has been talked about a million times..its low buck easy and you don't have to fight with U bolts on the axle..if your going to cut the front one put them in a bucket of water clamp a set of vise grips on where you want to cut and use a wiz wheel...also if you plan to do any work out back go spray the bolts TODAY with some PB blaster
Old 04-14-2010, 10:38 PM   #12
flashed
My truck was dropped by heating the coils by previous owner and it sucks big time. It bounces over bumps and the ride quality is terrible. I am going to replace them with stock ride height springs that a friend gave me. I do like the way it looks but not the way it rides.
flashed is offline   Reply With Quote
Old 04-15-2010, 12:18 AM   #13
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Like others have said DON'T heat the springs, it screws them all up.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 04-15-2010, 09:38 AM   #14
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
DONT do it.
Tom Vogel is offline   Reply With Quote
Old 04-15-2010, 09:28 PM   #15
jgrisafi
Velocity Speed Shop
jgrisafi's Avatar
Definately do not heat the coil springs. This is what my truck looked like when I bought it home the first day. I spent the money and bought new 5" drop springs for the back.
My Build Thread ..... http://67-72chevytrucks.com/vboard/s...d.php?t=288143
My Garage ..... http://www.hubgarage.com/mygarage/OCD69
jgrisafi is offline   Reply With Quote
Old 04-15-2010, 09:44 PM   #16
davebloomer
davebloomer's Avatar
someone heated the springs on the 70 GMC I used to have and it rode awful. I'd hit a bump at 65 mph and it would drop down a gear!!! not good.
nothing wrong at all with cutting the front ones just don't cut to much or you will run into geometry issues. Like stated the rear is a whole other issue. Looks like the jeep springs are a good idea.
FYI I recently cut 1 1/4 coil off my front and used a 5" rear lowering kit from ECE and this is my final result for only $400 rides good too.
davebloomer is offline   Reply With Quote
Old 04-16-2010, 12:32 AM   #17
epashhans
epashhans's Avatar
I've already got 5" drop rears, but I am really curious about the jeep springs. Anyone with pics? What years of jeeps? Why aren't more people doing this?
'67 C-10 Shorty - 454, 5spd, and speed holes!
epashhans is offline   Reply With Quote
Old 04-16-2010, 12:43 AM   #18
stevencvn72
Kill Bill...et
stevencvn72's Avatar
That's almost funny! There's only half of a coil that's not touching the others! Crazy that it wasn't sitting on the bumpstops.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 04-16-2010, 02:12 AM   #19
darthwall
years ago I worked at the local chevy dealership over here and one saturday when we where closed heated the fronts up well as everyone has said dont do it well it lowered the truck but rode rough then later I clamped the rears down and welded them together got the looks I wanted but rode like crap now im going to do it right time for the resto
darthwall is offline   Reply With Quote
