Old 04-15-2010, 05:41 PM   #1
corvette6698512
trans question
Quick transmission question. I want to put a sm465 into my '68 c10. It currently has the factory 3 speed and 292-6. I am wondering if the clutch, throw out bearing and all that will fit in the sm465. Also curious what I will have to do for driveline setup. Thanks guys.
corvette6698512 is offline   Reply With Quote
Old 04-15-2010, 08:31 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: trans question
Main thing to worry about is that you will need a high hump floor section if your truck doesn't already have one.
Old 04-16-2010, 12:52 AM   #3
corvette6698512
Re: trans question
Ok, that makes sense. So I need to cut the old panel out and bolt on a new one? Where could I find a new panel? Or maybe its easier to make one? Thanks.
Old 04-16-2010, 03:34 AM   #4
corvette6698512
Re: trans question
Another question. How hard is it to swap a 5 lug 12 bolt rearend to 6 lug? I broke my 6 lug rearend(twisted the diff housing) so I do have my 6 lug for parts. Can I put the axles from my 6 lug rearend into the 5 lug?
Old 04-16-2010, 06:46 AM   #5
Tx Firefighter
Re: trans question
No, the axles on your 68 are shorter than 71-72 axles which is the year range you will find 5 lug axles.
