06-06-2012, 10:26 PM | #1 |
front tires now sticking out too far and rubbing after disc brake conv
So now that I have converted my front brakes to discs I've noticed that the wheels and tires stick out from the frame of the body causing them to rub on the frame when i go over bumps. Is there anything else I can do without having to change to a thinner wheel in the front? Or if that is all I can do, do you know if they make this same design wheel in a thinner format so I could keep the rear wheels.? Any input, opinions and ideas are all welcome. thanks heres a pic of the wheel design |
06-06-2012, 10:51 PM | #2 |
But Found Her 25yrs Later!
Re: front tires now sticking out too far and rubbing after disc brake conv
Did you use a kit for the conversion?
If so, what kit did you use? There are some that move the wheels out, and some that supposedly don't. Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
06-06-2012, 11:07 PM | #3 |
I've never seen a kit OR a crossmember swap or anything move them out THAT much though - wow. Having said that, those are pretty wide front tires - do you have a "before" pic that preceded the conversion? I'm curious like LostMy65 as to how you did this mod.
06-06-2012, 11:24 PM | #4 |
Looks like a wheel backspace prob but i aint no xpert
06-07-2012, 04:05 AM | #5 |
Im gonna look thru my pics when i get home to see how far they had already stuck out before the conversion. I do remember noticing how wide the front tires were when I first bought it.
As far as what kit was used Im not 100% sure because I let my friend who owns a shop do that job and I was gonna order a kit from performanceonline.com but he said he could get it a little cheaper thru his guys so I let him. I hope I dont end up regretting that.. edit: ok i just found a pic b4 the conversion and they may have already stuck out a bit from what i can see from this angle. I think between the conversion and the lowering spindle it just really magnified it. as you can see from this pic these are ridiculously deep dish wheels so does anyone know what this style wheel would be called so I can shop around for a smaller size..... Last edited by N2TRUX; 06-07-2012 at 11:05 AM. |
06-07-2012, 06:29 AM | #6 |
Rim back space issue
06-07-2012, 10:57 AM | #7 |
The widest rim you can use with the disc brakes is eight inch with a standard back space, you have a ten inch rim under there now...
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
06-07-2012, 11:06 AM | #8 |
i would look on american racing.com.
1967custom |
06-07-2012, 11:13 AM | #9 |
What size tire are you running?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
06-07-2012, 11:25 AM | #10 |
Yes, the kit probably moved your wheels out 3/4" per side. As do most kits.
Cpp claims that theirs will not move the wheels out. Posted via Mobile Device
06-07-2012, 11:32 AM | #11 |
If CPP are using the modular spindles from the newer trucks, that is correct, I believe Capt Fab has all the part numbers to convert to the modular spindles...stock height, stock parts.
06-07-2012, 11:33 AM | #12 |
I don't think those wheels would have worked even with a CPP kit. As Rich said 10" wheels are too wide for the front on a lowered 60-66.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
06-07-2012, 01:16 PM | #13 |
me two interested....
what is the back space ? and is your wheel 8" or 10" ? i assume you have no rubbing problems with caliper or tie rods ? i am doing drop/disc too. let us know what you find out. thanks probably a 6 " wheel would work !!! |
06-07-2012, 01:40 PM | #14 | |
Senior Enthusiast
Here's a photo of a set currently on Ebay (although not for a 6 lug truck application): http://www.ebay.com/itm/Ford-Centerl..._Parts&vxp=mtr
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
06-07-2012, 11:42 PM | #15 |
60-66 Nut
I agree, the 10" wheels are just too wide for on the front of a lowered truck. 8" wheels may work, but might be close as well.
Genuine Centerline wheels have their name engraved right on the face of the wheels. Those look like a different brand to me. Maybe American Racing Wheels
06-08-2012, 01:53 PM | #16 |
My front wheel are out wider also with drop spindle. disc brake conversion and I used 8 inch chev truck ralley wheel and it worked out good, I think they are a 4 inch back space rim.
06-08-2012, 03:19 PM | #17 |
nice looker. i can see that with your truck... 6 inchers ought to put the wheels inwards such that the front can even get a little lower ....
got any links to details of your truck ? thanks for posting. paul |
06-08-2012, 06:38 PM | #18 | |
Here's a post from another thread that is worth posting here:
06-08-2012, 08:53 PM | #19 |
hey thanks alot guys for all the input! I'm gonna have to agree that these 10" wheels are just not gonna work. I checked the face of the rim and its completely blank so not sure what they are but those Centerline wheels you pointed out Markeb01 look almost identical. So are these rims considered 'rally' ??
Hopefully I can find someone that might wanna swap out just two of their smaller rims but i know that's a shot in the dark. too bad I just bought brand new tires heres another close up shot Last edited by chadh100; 06-08-2012 at 09:17 PM. |
06-13-2012, 08:46 PM | #20 |
So what's the end result? Have you solved your problem?
58 Apache short fleetside ona 64 chassis: |
06-14-2012, 12:26 AM | #21 |
