1st Project - 1972 Stepside
I bought this for $2,700 including a brand new Oak Bed kit with hardware. What do you guys think? In addition to the fender, I have to replace the passenger rocker panel. It has a straight 6, manual brakes, manual steering, and 3 speed on the column. I 'm convinced it was a bargain, and I'm the second registered owner!
laying low
![]() Join Date: Mar 2001
Re: 1st Project - 1972 Stepside
Welcome to the forums Bruce.
I'd say you did alright with that one. Gonna replace the fender and rocker and drive it as is or do you have big plans for it? It looks about like my 69 when I got it.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Its a Truck Thing......
According to how under the hood loooks, Id say you stole it, especially with a new floor kit too. All that manual stuff can be upgraded and Id leave in the 6 and put HEI on it. The only challenge with the 6 is finding a complete PS set up, but you guys in CA seam to have everything........
Nice truck to start with.... Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
It looks like you did well. All stock and looks pretty solid. Nice history. Interior looks great too.
yea, looks like you did well....whats the plans for it?
![]() What are your plans for the truck shy of the things already mentioned? At any rate good find and best of luck with all your upcoming endeavors.
- 1967 Chevy C10 shortbox - 1984 Chevy K10 "Mater"- SWB 305 manual, retired sheriffs truck, Current Frame Off Project - 1986 Chevy K10 LWB 350/350 Daily Driver/project |
70 Chevrolet=Obsession
Welcome to the board! Nice Step. Looks like that fender isn't so bad that you couldn't hammer it out and Bondo it.
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
67-72 parts collector,…
![]() Join Date: Nov 2002
Nice.
Keep those "updated pictures" coming,...
Here's a list of purchases to date:
- Power Brake Booster (original used) - Power Steering Gearbox and Pump (w/Bracket) - 5.7 L V8 from a 94 full size. Edelbrock RPM Air Gap Manifold with 650 Edelbrock Carb - 350TH Trans (Rebuilt) - Used A/C system (no pump) - Driveshaft (needs to be shortened) - Automatic Steering Column (original used) - New Dash Bezel (New) - Replacement Rocker Panel (New) - Replacement fender (original used) - Replacement Grille surround (original used) - New Mirrors, but I can't see out of the passenger side! I was able to get all the parts above for about $1,300 mostly from Craigslist. I think I have all the parts to convert it to power everything, V8, automatic with A/C. I almost forgot the wheels, 15x8 and 15x10 Corvette style Rallys powder coated black (no caps or rings) another $300. What do you guys think about keeping it the original color, Med Grn? I was toying with black, or a black and silver two tone with the original color as the pinstripe. I have more than enough to keep me busy for a long time. I'll post updates as I make progress. Thanks for all the great feedback! |
![]() Join Date: Apr 2009
You Didn't install the Motor and Trans Yet..
I need to buy a cross member and shift linkage before I continue, so I'm still fundraising. What up Danny!
Guess what I found underneath the carpet...the original key! I pulled the carpet up to inspect for rust and there it was. It hadn't even been punched out to fit on your key ring. The key I have I needed to jiggle the driver door lock, but the original works like a charm. I made a copy and that works great too. You never know what you'll find when you start the disassembly.
My buddy pulled up the carpet on his VW Bus, he found a little mirror with a razor blade on top of it. I guess the boys in the factory really knew how to party. |
#13 |
I might have a cross member I'll look give me a call.
#14 |
Thanks buddy, I'll give you a call tomorrow.
#15 |
Tot Roddin'
dabruce15, I think you scored in a big way when you purchased that stepper. IMO, I love the color, but then again I might be a little biased.
![]() Can't wait to see this build come together. And I6's are still pretty cool. ![]()
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#16 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Welcome to the board from southern oregon nice stepper for sure if ya need a crossmembe I may have one??
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#17 |
Pic of the wheels.
#18 |
New dash bezel and painted the needles.
#19 |
Old Duffer
![]() Join Date: Mar 2003
I think you did very well!
I agree with 72blckbuty, sixes are cool!
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
#20 |
![]() Join Date: Jan 2008
Very cool truck, if you pull the seat, you might find the original build sheet hidden in the springs!
#21 |
1968 C20 Vortec Beast
Before youreplace that driver fender dig around on here for a bit. I just saw where a member made a dent puller plate that will take out that dent beautifully. somebody help me out here. Secondly spend some clay bar and buffer time on that paint and you might be surprised.
Ugly or not it still kicks a**! |
#22 |
The lower pocket of the fender is rusted through. So I opted to replace it with one I found on craigslist for $50. It had holes in it for molding, so I'm filling the holes.
#23 |
looks like a good project, looks good for $2.700.00
#24 |
Update: Put the rallys on today, looks good, but I definitely to find some trim rings and caps now.
#25 |
Nothing to see here.....
![]() Join Date: Jun 2007
call me a different bird, but those black rallyes look great..... naked!!
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
