Old 01-11-2010, 07:02 PM   #1
stevewhitmore
stevewhitmore's Avatar
New Coil Springs height versus old?
Help
Just got my new 2" drop rear coil springs but the height is exactly the same as the old ones (not installed), is this right?
The old ones do look as if the middle three coils have been compressed
Thanks for any guidance
stevewhitmore is offline   Reply With Quote
Old 01-11-2010, 07:09 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: New Coil Springs height versus old?
Very likely.
It happens all the time.
These drop springs are 2" shorter than a "brand new" stock height spring.
(not your sagging or possibly "heated" 40 year old springs)
That's why I always suggest looking at the "stance photos" on ECE's (www.earlyclassic.com) website.
These pics will show you what their drop spring products look like installed on a similar truck.
Can you send these back?
Old 01-11-2010, 08:06 PM   #3
stevewhitmore
Here is a pic of what I am talking about
The front was not lowered and I was just trying level it out so I thought 2 inches drop would do the trick
Do you think the new ones might compress the 2 inches?
Old 01-11-2010, 08:13 PM   #4
lolife99
lolife99's Avatar
I'm not sure.
A 2" lowering block would definitely bring it down 2".
Maye you could tape up the contact areas of the new springs and just let the weight of the truck down on them.
(no bolts)
Did you take any measurements of the rear height before you removed the stock springs?
Old 01-11-2010, 08:23 PM   #5
stevewhitmore
I meant to take measurements but like a dummy I forgot to in my haste to get the old ones off. What is this I hear about heating the springs to lower them?
How do you do that?
I am on the east coast and got them from the west coast so the cost to return is probably to high cause they are pretty heavy.
Old 01-11-2010, 08:24 PM   #6
heyjoe
Those old springs look like the heavy duty option I took off the back of my '67 C20.
'67 C20 small window Fleetside - 250 inline 6 - 3 on the tree - heavy duty clutch, brakes, rear springs - 17.5 wheels w/bias ply tires - AM radio - heater.
heyjoe is offline   Reply With Quote
Old 01-11-2010, 08:28 PM   #7
stevewhitmore
The new ones don't seem to be as heavy and stout as the old ones although the round diameter is the same
Old 01-11-2010, 08:29 PM   #8
lolife99
lolife99's Avatar
NEVER heat springs.
Old 01-11-2010, 08:57 PM   #9
Shane
Shane's Avatar
NEVER use lowering blocks larger than 1.5" inches with 15" wheels.
Shane is offline   Reply With Quote
Old 01-11-2010, 09:07 PM   #10
stevewhitmore
Interesting fact, but that is what I have - 15 inch wheels with 255 / 70 / 15 tires. I think I will put the springs on and hope for the best. I was just trying to level it out with the front, but I don't like the heating idea or the blocks.
Good thing I did take the old ones off though because the passenger side was completely broken at the top pigtail at the clamp
Old 01-11-2010, 09:11 PM   #11
Have you installed these or are you judging them to be the same on a bench?Don`t heat the lowering spring.That will ruin them.Guys heat stock springs until they settle to desired height.They no longer function as designed.Lowering springs are designed to compress to desired height under stock height.
Old 01-11-2010, 09:12 PM   #12
stevewhitmore
I actually got the 2 " idea from the LMC catalog cause it says the factory stance was 2 " higher in the rear
Old 01-11-2010, 09:16 PM   #13
stevewhitmore
Special K
I am just going by what they look like on the bench, but hoping they might be the 2" drop when installed?
Old 01-11-2010, 10:25 PM   #14
rsavage
rsavage's Avatar
Your original rear coils look like progressive rate type springs ( see the three closely stacked center coils). I would bet that the new springs will sit lower as they will compress further. Keep us posted.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 01-11-2010, 11:21 PM   #15
big_al_71
big_al_71's Avatar
I agree that once the new springs go on they will be lower....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-11-2010, 11:58 PM   #16
1968CHEVYC10
1968CHEVYC10's Avatar
they'll need to be broken in some once you get them in your truck, give 'em some time to settle.
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 01-12-2010, 12:14 AM   #17
clay68c10
clay68c10's Avatar
Yup, slap the new ones in there and give it a couple of weeks to settle out.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 01-14-2010, 04:14 PM   #18
stevewhitmore
Did some research on the old springs and found out that they are what is known as "variable rate" springs or progressive rate as someone else chimed in earlier.
So, the new ones are going on this weekend once I get the garage warmed up so wish me luck on a 2" drop
Thanks for all the idea's and help
Old 01-15-2010, 01:35 AM   #19
tap500
Heating springs is a big no no. Sure it is cheap but it destroys the springs. Springs are heat treated to harden them and provide the sping. This is a special process. Heating with a torch at home destroys the hardening and does not recreate the process. You did the right thing spending the $120 for drop springs.
tap500 is offline   Reply With Quote
Old 01-17-2010, 08:59 AM   #20
stevewhitmore
Well, got the new springs on, now just sitting around drinking a cold one waiting for them to drop cause the 2" drop didn't happen, just wondering whether I got the right springs
Old 01-17-2010, 07:04 PM   #21
stevewhitmore
Clay68C10
Most likely a dumb question but does it have to be driven to get the springs to settle?
Old 01-17-2010, 08:47 PM   #22
big_al_71
big_al_71's Avatar
Originally Posted by stevewhitmore View Post
Clay68C10
Yes!!!! I did drive my truck a bit before the suspension really settled.
Old 02-01-2010, 07:45 PM   #23
degree01
Maybe the old one's were already 2" drop springs and you were not aware of it, so when you purchased 2" lowering springs you got the same? Just a thought.
degree01 is offline   Reply With Quote
Old 02-01-2010, 09:00 PM   #24
stevewhitmore
Not sure what is going on but I took it out on the roughest back road I could find and came back to the same height. It has been two weeks and no drop so I am not sure what my next move is but I needed new springs anyway because one of the old ones was broken.
