06-09-2005, 02:36 PM | #1 |
Stupid Question.
Ok, now to most of you here this is probably a stupid question... but my father always told me that the only stupid question is one not asked... so here goes.
When I bought my truck the windshield washer fluid worked fine.. now the wipers work still but I'm not getting any fluid when I call for it... and yes, I checked the fluid level first I don't know exactly how it works but I'm assuming there's a pump of some sort that is activated when you turn the switch on... could the pump be fried? or??? any help would be appreciated. thanks ttfn Mystic.
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- 'Wow ... what a ride!!!" |
06-09-2005, 02:43 PM | #2 |
my gas saver
just listen to see if the pump comes on. should make a whining noise like an electric fuel pump....... then go from there.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
06-09-2005, 04:05 PM | #3 |
'87 V20 4x4
if not the pump you might also check your fuses... Doc
'86 K5 Blazer 4x4 FOR SALE '87 v20 4X4 '99 S10 Blazer 4X4 |
06-09-2005, 05:04 PM | #4 |
are your rubber hoses connected and\or are they free of weather cracking and just not reaching your windshield good luck
square body trucks an addiction or an investment either way they consume all my extra time and money |
06-09-2005, 05:24 PM | #5 |
Make sure that the ends of the squirters arent clogged or make sure your uncle didnt paint over them......like what my uncle did.
06-09-2005, 08:56 PM | #6 |
If the motor runs, and you don't see any leaks, yet you still aren't getting fluid, stick a needle down the nozzles to unclog, or blow compressed air from the nozzle end back to the reservoir.
Real Name - Brandon Current Vehicles: 1977 C20 Silverado 454/TH400 3.73s 1989 Jaguar XJ6 in the middle of an LT1/4L60E swap |
06-11-2005, 11:12 PM | #7 |
I'm betting the pump is dead. A good diagnostic is to see of the connector is getting power when the switch is actuated. Another is to hook up the pump to a 12V source. If it runs, your problem is farther up the line.
The above advice is all good, by the way. Good luck!
Semper Paratus Last edited by KShortell; 06-11-2005 at 11:13 PM. |
06-13-2005, 09:38 AM | #8 |
Disconnect the hose from the washer bottle and blow through it. If it's not plugged, replace the pump. I got no windshield juice from mine, even thought the pump would hum. The hose/nozzles weren't plugged, so I took off the washer bottle (the pump is attached to the back of it) and the pump was like swiss cheeze. It crumbled to death when I tried to take it off. Anyway, I got a direct relplacement for like $15 and now I have nice clean windows.
06-13-2005, 11:16 AM | #9 | |
Stepsides RULE
If that's the case, and you don't feel like doing surgery on your wiper motor, LMC and Chevy Duty sell (i think its the same) "universal" wiper motor, i bought one and it works great. You just take the power from the old pump, and bring it to the new pump, and mount the new pump to the fender. Tis' times like these I wish i had a digi camera so i could show you mine.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
06-13-2005, 08:11 PM | #10 |
Well guys, thanks for all the advice.. turns out the motor was fried. Replaced the motor and everything is all hunky dory again
thanks again... it's appreciated ttfn Mystic.
