Old 06-11-2005, 11:05 PM   #1
KShortell
KShortell's Avatar
Woo hoo! Fixed the A/C noise.
Well, I finally solved my "groaning" compressor noise. It turns out that a couple of the compressor to bracket bolts were loose, one even out completely and rattling against the refrigerant lines. That was actually a good thing, preferable to losing it altogether. I tightened them up and no more noise.
I love it when it only costs time to fix a problem instead of money. I only wish I'd have solved it sooner.
Of course, now I need to put the Jeep in the shop. The air gap on it's A/C compressor clutch is a hair too wide at the upper end of the spec. The clutch starts to get intermittent in its operation after a few miles of heating up. Not having a compressor clutch removal tool nor the time to do it, I'll take it to the honest mechanic around the corner. Yes, the Jeep has a soft top, but it does get hot, humid, and rainy all at the same time here in the Mid-Atlantic. A/C is the only way to defog the windshield!
Semper Paratus
KShortell is offline   Reply With Quote
Old 06-12-2005, 02:03 AM   #2
1976K5CHALET
1976K5CHALET's Avatar
A/c
Remove the nut on the pulley ...rent the tool from autozone or checker and push the outer clutch hub in a little to take up the gap. Works like a charm.
Just rebuilt the a/c on the wifes 90 V2500 Burb and had the same issue with a reman Apco Air compressor (the best remans out there) this week...with the exception that i own all the tools.
DW
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
