01-12-2011, 07:29 AM | #1 |
55-57 rear ends
So what rear ends are everyone running on the stock width frame on 55-57 trucks? I want to pull out the stocker and find something that I can use that will maybe allow me to mount a larger wheel/tire combo without modifying frame or wheel tubs. I am running camaro front suspension so the bolt pattern will have to match it.
01-12-2011, 08:56 AM | #2 |
Re: 55-57 rear ends
I went to a 69 chevelle 10 bolt to keep the stock width.
tbrown |
01-12-2011, 09:03 AM | #3 |
Re: 55-57 rear ends
I have access to a 73 laguna/chevelle posi rear..is this too wide?
01-12-2011, 09:20 AM | #4 |
Re: 55-57 rear ends
the problem is, with out tubing the inter fender 8" wheels is it. You can put a big wheel on with out moding the frame, but you will need to cut the inter fender.
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
01-12-2011, 10:20 AM | #5 |
Re: 55-57 rear ends
I'm running a 72 camaro rear axle. Had to weld on some spring perches, but the width is perfect for my setup. Plus if you can find a later model WS6 trans am version it will have rear disks.
Somehow, the idiots survive despite their best efforts to kill themselves. - dcozzi |
01-12-2011, 02:27 PM | #6 |
Re: 55-57 rear ends
I don't mind cutting the inner box panel out. I just don't want to have to cut the frame.
01-12-2011, 03:23 PM | #7 |
Re: 55-57 rear ends
I have a 79 Firebird under mine. It is almost the same width & has the bolt pattern for all the GM intermidiates.
