difference between sub/blazer tank
I want to take out a nos suburban gas tank that i found in a junk yard. Its clean with no rust and still has a GM sticker on it.
Are the sub and the blazer tank the same?? Randy ![]() ![]()
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
TTT
the fill neck on a suburban tank is different than a blazers due to the location of a body mount in front of the fill tube
![]() Join Date: Jun 2003
Suburban Gas Tank
Oldchev4x4, I just installed a new steel tank from 'The Truck Shop' that I picked up at the Carlisle show. It was advertised as a "direct replacement" for Blazers and Subs 67- 72. I installed it in my 72 longbed pickup and had to locate it about 2 inches farther to the rear along the frame rails to clear the bed mount that was in the way of the filler neck. It seems to be working out well, although I haven't filled it to the top yet. (Put 15 gallons in it and my gauge registered 5/8 of a tank!!) So, be aware that you might have to move the tank front or back depending on the vehicle you are working with.
i want to put the sub tank in the blazer.
The truck shop lists the same tank for both vehicles? But Rick says there differnt. Hmmm..... what to do........ Randy
blazer ones work in the trucks I have sold and installed lots of them, you do have to trim back one of the bed stringers that go side to side on the bottom side of the bed to make it fit flush, and then figure out how you want to fill it. but they will not fit in a suburban (I sell the same one the truck shop has for 255 + shipping, it comes with the tank, sending unit and straps and it is metal)
