Old 04-27-2024, 03:30 PM   #351
clay68c10
clay68c10's Avatar
Re: ClusterTruck; because that’s what it is
The first bend was pretty easy, it's just a U bend cut in half and flipped. The hangers are another stock Ford part. I'm using 3 per side. They're pretty stout and easy to work with. The metal rods are generic from Amazon. I made the bolt hole portion of the mounts from 3/16 flat stock.
It's always surprising how long these things take... This was a whole saturday, but to do it again would probably take 1/3 the time.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is online now   Reply With Quote
Old 04-27-2024, 03:47 PM   #352
Steeveedee
Who Changed This?
Steeveedee's Avatar
What are the devices near the start of the pipes, before the "H" pipe? Cats or resonators?
~Steven
Simi Valley, CA
Old 04-27-2024, 04:20 PM   #353
clay68c10
clay68c10's Avatar
Flowmaster bullet type cats. I've heard they work well.
I like that old school exhaust smell for about 2 minutes, then I'm out. Too many years of working in shops I guess.
13 Tahoe LTZ
Old 04-29-2024, 08:18 PM   #354
clay68c10
clay68c10's Avatar
The next round was a little more complicated. The pipes have to go over the rear, then the passenger side goes behind the panhard bar and the driver side goes in front. Then it has to clear the gas tank corners and go to the rear.
I started with the passenger side.
13 Tahoe LTZ
Old 04-29-2024, 08:23 PM   #355
clay68c10
clay68c10's Avatar
Then mirrored it on the driver side, just shifted aft a bit, and continued on to the back.
13 Tahoe LTZ
Old 04-29-2024, 08:25 PM   #356
clay68c10
clay68c10's Avatar
Then the passenger side.
13 Tahoe LTZ
Old 04-30-2024, 09:56 AM   #357
loudchevy
Active Member
loudchevy's Avatar
Nice work, are you using a kit of misc exhaust pieces? or just buying what you need? also what size diameter are you using?
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 04-30-2024, 12:52 PM   #358
clay68c10
clay68c10's Avatar
Thanks. It's been an interesting process.
I bought the universal box of mandrel bends from Speedway. It's the 2.5" version.
I got their H pipe kit and also added the optional extra box of straight pieces they have for pickups. The H pipe was handy, but I haven't needed any of the straight pickup kit tubes.
The pieces all come with one end expanded for slip fitting. That was handy. I only had a couple of pieces to butt weld; at the rear downward portion of the axle kickup and the front S shape before the mufflers. Both of those sections got welded in my vise and then put back on the truck.
13 Tahoe LTZ
Old 04-30-2024, 01:01 PM   #359
loudchevy
Active Member
loudchevy's Avatar
Thanks for the info. I was looking at those Speedway kit as well. Their Phx store/warehouses is actually a few miles away from my office, which is convenient.
What muffler did you end up using?
Scott
2003 Tahoe Stock
Old 04-30-2024, 02:04 PM   #360
clay68c10
clay68c10's Avatar
The Flowmaster Flow FX. Those should be fairly mellow. We'll see.
13 Tahoe LTZ
Old 05-01-2024, 07:43 AM   #361
hewittca
hewittca's Avatar
Nice work on the exhaust! That combination of bends you used is similar to what I ended up with to get over my rear axle. I'm curious to hear your exhaust with the H-pipe and those mufflers. With mine, I have the X-pipe so far back that it gives the exhaust a bit of a weird tone. I'm thinking about changing it to something like you did here.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 05-01-2024, 10:43 AM   #362
clay68c10
clay68c10's Avatar
Thanks, it turned out ok.
Interesting, I never thought about the location of the crossover and it's effect on the sound.
Eventually, when I get it running, I'll take a YT clip of it and post it up.
13 Tahoe LTZ
Old 05-01-2024, 01:14 PM   #363
SCOTI
SCOTI's Avatar
I recall reading the farther upstream a cross-over is, the more it can help with 'taming' the sound.
Resonators & 'Helmholtz Chambers' are becoming much more common on big HP (& not so coincidently big $$) builds in efforts to keep things reasonable.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-03-2024, 07:52 AM   #364
clay68c10
clay68c10's Avatar
There's some interesting technology there. I'd like to see under some of the newer factory fast cars and how they've been doing things.
13 Tahoe LTZ
Old Yesterday, 10:21 PM   #365
clay68c10
clay68c10's Avatar
The cab has been at my friends shop for bodywork. We’re doing a labor trade for the body and paint. He’s got a couple of hot rods that need done and I’ve been helping him with mechanical and electrical items.
He does nice work, and it’s slow. It’s slow because he likes to let all the products cure before going onto the next step. Over the spring that can take a while because heat really speeds up the cure.
Anyway, here’s some pics of the cab.
13 Tahoe LTZ
Old Yesterday, 10:37 PM   #366
clay68c10
clay68c10's Avatar
The cab I have was dry and clean-ish, but it definitely had been worked hard. The back had a lot of dents. Dave and I got a lot of them out with the stud gun, then it was time for a skim coat. He has a cool sanding technique that gets the panels pretty flat. He uses these very long sanding blocks and a powder guide coat.
These pics are of a door, but the same technique applies. Those long blocks really show the imperfections, and eventually smooth them out.
13 Tahoe LTZ
Old Today, 09:02 AM   #367
clay68c10
clay68c10's Avatar
Here’s where he got the idea. https://www.linearblockingtools.com/
He makes his own with plexiglass and vinyl tubing.
13 Tahoe LTZ
