Chevy nut
Is this right?
I was looking at the rear springs on the stepper...and I noticed that 3 of the coils looks like they are collapsed. Is this they way its supposed to be?
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
Re: Is this right?
No.They were probably heated to lower or settled that way.The center wraps are closer than the outer when new.
Chevy nut
Re: Is this right?
Thats what I thought. I noticed on my fleet with overloads that the springs sat up higher. So I might take the springs off the trailer and use them.
![]() Join Date: Apr 2004
Re: Is this right?
I agree with special-k, those were heated.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
Re: Is this right?
3/4 springs?
1972 GMC Sierra 1972 GMC Super Custom Suburban |
its all about the +6 inches
Re: Is this right?
they are supposed to be like that.
Variable rate springs. You get the ride quality (soft ride) from the center 3 rings, once you put a load on there, they stack up, and then the rest of the spring takes over, with a higher spring rate. |
Re: Is this right?
"Variable rate springs" so that's what they're called. Thx Andy, learning something almost everyday here.
Re: Is this right?
no problem Al.
![]() Join Date: Sep 2005
Re: Is this right?
thats how mine are i just figured mine for wore out guess not i was going to replace all mine to thanks now i know
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Re: Is this right?
Not sure how you can get good ride quality from springs that are touching each other. Please explain. Are you saying that they shouldn't be touching.. but they will under heavy load?
#11 | |
C10 addict
Re: Is this right?
I could be wrong, but I don't believe those are progressive (or variable) rate springs. On a progressive rate spring, the closer coils are always on the top, from my experience. They also won't completely compress during static loading, i.e. with the truck just sitting there. I would bet those were heated to lower the truck.
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS |
#12 | |
Son of a gun
Re: Is this right?
Bill BEATERS ARE NEATER Last edited by Bus Ted Knuckle; 06-13-2008 at 08:32 AM. |
#13 |
Chevy nut
Re: Is this right?
I wish the SPID was still on mine. I looked at the other springs I have and they are the same. One thing I can....Andy has never been wrong!
#14 | |
Re: Is this right?
![]() I can't wait to see his response to that^^^ |
#15 |
MOVE OVER
Re: Is this right?
Andy thought he was wrong ONCE,, but he was mistaken.... ![]()
No matter where you are..... There you are... Buckaroo Banzi |
#16 |
![]() Join Date: Apr 2008
Re: Is this right?
Im pretty sure the ones on mine look like that and I know gramdpa didnt lower his truck.(unless loading it counts)
#17 |
1970 Daily Driver
Re: Is this right?
When I put new drop coils in my truck the old ones looked just like those. Before I pulled them my truck was at stock ride height. I asked an old chevy dealer mechanic and he said the same thing Andy did. It looks wierd but that is the way they came, not because they were heated.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
#18 |
Re: Is this right?
I've been wrong PLENTY of times.
HD optioon springs were not progressive as far as I know, but I have never owned HD coils. I do know the rear springs on my old GMC were stock replacement for a base model 1/2 ton, bought in the 80's (from the dealer) and installed in the early 90's, and were exactly like that, as were just about every coil spring I have ever looked at on these trucks. The 3 center rings are not supposed to be touching, but only 1/8 inch or so apart. Once they are all 3 stacked up and solid, then you are riding on the rest of the spring. Those are stock style... if not original 40 year old springs. They may have sagged a little and be almost stacked up at the rest position. But, that IS pertty much what they are supposed to look like. If they were heated, you would see evedence to the fact too. Either burn marks if recent, or very bad rust in the burn spots if not so recent. |
#19 |
Re: Is this right?
Another thing I just noticed today while under the burb... my 72 C/20 suburban has the coils like that, and it sites higher oin back than my C/30 longhorn.
#20 |
so easy a caveman can do it...
![]() Join Date: May 2006
Re: Is this right?
1969 C-10
Old & New HD: |
