04-28-2013, 07:36 PM | #1 |
Big block, small block
Hello, new to thew forum. I am fortunate and actually have a choice, would like some thoughts. I have a 1967 C10 Arizona truck that i am going to restore, frame up. I have a 1971 350 V8 with a turbo 350 transmission, this is my choice. I also have a 1986 454 V8 with a turbo 400, newly rebuilt. I am going to build the small block and use that, truck will be a driver not a sitter. But which transmission? I will use truck to tow boats and medium size trailers. I am thinking turbo 350, 400 is heavier. Anyway, any thoughts?
04-28-2013, 07:48 PM | #2 |
Re: Big block, small block
I would use the 400 in place of the 350. will last longer when towing... or you could just drop in the 454-400 and all your problems would be solved
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother |
04-28-2013, 09:25 PM | #3 |
Definitely the turbo 400. I built up a small block one time. Dad's bone stock 454 vortec would way out pull my sbc. They both got horrible fuel mileage when towing.
04-28-2013, 09:31 PM | #4 |
yep, they both get poor mileage when working so you might as well have the power. Go big block and turbo 400. However, i would change the 400's first gear from the anemic 2.48-1 ratio to the deeper 2.75. It really helps the truck off the line under load.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
04-29-2013, 01:02 AM | #5 |
Hey sam059 ...
Just wanted to say to the forums and from Ohio.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
04-29-2013, 08:29 AM | #6 |
350 and TH400 trans
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
04-30-2013, 12:17 AM | #7 |
Go big block if you have it
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly |
04-30-2013, 12:21 AM | #8 |
Moderator
Th400
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
