Old 07-21-2003, 10:18 AM   #1
VTKidder
Cargo light switch location?
About sums it up. Can someone describe and post a pic of where the cargo light switch is located from the factory? Thanks all....
VTKidder is offline   Reply With Quote
Old 07-21-2003, 10:29 AM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Adam,
Centered directly underneath cab interior light. I don't have exact dimensions but it is centered below. You need to cut a rectangle hole for the switch to set into.
Wish I had a pic...
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 07-21-2003, 11:44 AM   #3
SLS
Finish the'71..or bust!
SLS's Avatar
Heres a pic from my '71
I hope this helps:
SLS has attached this image:
The top of the switch butts up against the raised ridge at the bottom of the courtesy light hole....and all is centered in cab.
My switch is a tad crooked...so I'm not sure whether this one was installed by the factory...or some jackleg at the dealer. Just another thing on my mile-long list of stuff to fix...LOL.
Sorry for the 'dirty' pic...but it is one of the cleanest areas on this ol' truck.
SLS is offline   Reply With Quote
Old 07-21-2003, 01:15 PM   #4
VTKidder
Wow.....ask and you shall receive. Thanks for the info and pic guys. Thanks again Jeff.
Old 07-21-2003, 07:05 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Mine was a little off center, and I know it was original.
