Effort in closing the doors
It's been a very long time since I used to cruise the drag in a 72 blue and white beauty. Now that I am restoring my truck I am curious. How much force should it take to close the doors. Should the mechanism fit like hot butter with little effort or is a good firm slam normal. The doors close fine but you have to be somewhat forceful.
Re: Effort in closing the doors
Are your door seals new? When i put new ones in i had to slam my doors for awhile till they softened up
1967custom |
No they are not new. Not even close to being new.
20' Daredevil (Ret)
![]() Join Date: May 2003
Seals were my first thought also. Since they are apparently not the problem, and it sounds as though the truck has been sitting a long time, try lubing the door latch mechanism. But even if everything is perfect, I wouldn't expect the doors to close "like hot butter". It's an old truck, not a new Mercedes.
try lubricating the door hinges every 40years or so they like it
Check your hinges too. Hinge might be wore out and door is dropping a couple hairs and when you close the door it lifts back up on the latch assy.
1967custom |
Check the bolt heads on the hinges, the upper one's in particular. See if there clashing with the hinge when it's closed, look at the adjacent surface and see it the paint has a imprint of the bolt head in it.
Thanks guys I will give it all a go tomorrow! Love this site!
Old member
You may need to adjust the door hinges and the striker plates. It took me forever to get the drivers door so it would lock with the key without pushing in on the door while I locked it. It's so much better now but it is not like butter by no means!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#10 | |
Thanks Dan |
![]() Join Date: Jul 2014
I have the same problem with my 68, I got the passenger door working great, but can't seem to get the drivers door right.
#12 | |
Old member
![]() Quote:
#13 |
Thanks Andy. I will work on that today. Great thing about being in Florida. Don't have to wait for warm weather....
Dan |
