Old 01-22-2014, 12:43 AM   #1
Belairboy55
Active Member
Short & Long Bedsides; 69-72 steering wheel;Dana 14 bolt Posi
I have a pair of SWB bed sides that are in rough but useable condition. Some small rust with a few dents and dings. $150.00 per side. I have a perfect pair of OEM wheel tubs that are $100.00 for the pair. I have a rust free perfect front bed wall for fleet side metal floor bed $100.00. I have a perfect pair of LWB FLEET SIDE bed sides that have one repaint on them and a few holes drilled in top rails $200.00 per side. I have a very straight LWB FLEET SIDE steel bed floor with two small rust spots on the high side of a floor rib $150.00. I have a non tilt auto column $75.00. I have a 1969-1972 Chevy steering wheel that is in very good shape with one small crack $80.00. I have a Dana 44 front axle 6 lug disc brakes 373 gear that is complete and in working order $300.00. I also have a 8 lug rear end 14 bolt full floater with a 373 POSI it needs carrier bearing. The bearing has been removed $150.00. Also have a 1970 Cab with title that I will sell hole or do cab cuts. Located in Lake Charles LA 70605. Would rather not ship.
Belairboy55 is offline   Reply With Quote
