Old 02-27-2008, 06:21 AM   #1
squarebody
pics of 5/5 drop please
Im new here, can any body post some pic of their drops with info such as drop,rim width,b/s, tire size. have a 86 silverado swb going with 5/5 drop stock rallys 15x8. 275/60 rear 255/60 front. planning on a flip kit(no c-notch) 3inch spindles 2 inch coils (hear i have to do some grinding on the lower control arms) does this sound feasable? i will appreciate any help! this is a budget beater for now.
squarebody is offline   Reply With Quote
Old 02-27-2008, 10:35 AM   #2
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: pics of 5/5 drop please
This is my 83
4/5 drop(2 cut coils and flip kit)
15x9 shoes 4"BS
275/50/R15 TA's
Malo83 is offline   Reply With Quote
Old 02-27-2008, 11:07 AM   #3
slepysal
slepysal's Avatar
nice !!! what size tires/wheels ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 02-27-2008, 11:49 PM   #4
69BBsuburban
Right in front of you.
69BBsuburban's Avatar
Mine is about a 5/6 or so....flipped with no notch.....it's close to the bumpstops, which are aftermarket.
Stock 15x7 and 8 Rallys, 235/60-15's and 275/60-15's....
Pinstriping by Josh
'78 Chevy Silverado SWB (lowered, 454)
'90 Chevy Sport Truck
'68 Dodge Charger R/T
1930 Ford Model A
69BBsuburban is offline   Reply With Quote
Old 02-28-2008, 12:23 AM   #5
ton*loc
ton*loc's Avatar
so the flip kit is like 5 inches ?
1986 chevy c10 in the "build" process as we speak 358 flat tops, vortec heads, .500 lift cam, NOS power shot plate system, yada yada yada
MMA PIX http://www.clgpix.com/MMA/Fighters/F...C/CoteTony.htm
MMA RECORD 24-5
ton*loc is offline   Reply With Quote
Old 02-28-2008, 12:42 AM   #6
1LoC10
Insert Title Here
1LoC10's Avatar
That truck sits perfect... right on the tires.. nice
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 02-28-2008, 12:47 AM   #7
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
Here's mine with a 5/6 drop... running 17's back then.
CLASSIC87' is offline   Reply With Quote
Old 02-28-2008, 12:50 AM   #8
69BBsuburban
Yeah...the store bought kits are "generally" 5", it depends on the leaf spring packs....
But flipping a rear is so easy making your own "kit", that you can go lower if needed, just weld on new perches and use blocks (I always thought those U shaped "blocks" in flip kits were cheesy)....but anything over 5" needs a notch...honestly, mine could use a notch...it'd have a bit more clearance, esp. with a load...
Pinstriping by Josh
1930 Ford Model A
Old 02-28-2008, 01:37 AM   #9
68c10owner
68c10owner's Avatar
Originally Posted by Malo83 View Post
This is my 83
15x9 shoes 4"BS
275/50/R15 TA's
Looks great. I`d like to know the wheel/tire size
What did you use up front to get the drop? Looks great
What size wheel/tire were you running?
Anthony
68c10owner is offline   Reply With Quote
Old 02-28-2008, 02:03 AM   #10
dhughins
dhughins's Avatar
it says under maol's pic his tires size 275/50/r15 wheels are 15x9's
dhughins is offline   Reply With Quote
Old 02-28-2008, 02:33 AM   #11
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
Here's your info man:
Front:
17x8.5 with 255/60/17 Goodyear GTII tires 4" Back spacing
Rear:
17x9.5 with 275/60/17 Goodyear GTII tires 5.5" Back spacing
Thanks,
Anthony
Old 02-28-2008, 02:37 AM   #12
69BBsuburban
This was my stepdad's truck....when he was killed, my mom gave me the truck.....so I'm not certain the exact drop specs.... I do know it is a combo of springs and spindles. Probably 3" springs and 2" spindles, as there are no modifications or grinding of the A-arms or calipers, which is normally needed when 3" spindles are used with factory Rallys.....
I had an '80 with 3" drop spindles, and this truck is much lower.
Pinstriping by Josh
1930 Ford Model A
Old 02-28-2008, 05:33 AM   #13
slug
slug's Avatar
Heres Mine, She Has A 5/7 Drop. Flip Out Back With Drop Shackles And Drop Spindles/springs Up Front
slug is offline   Reply With Quote
Old 02-28-2008, 06:03 AM   #14
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
5/5 drop here
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 02-28-2008, 06:46 AM   #15
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Mine was a 5/5 before I decided to go air.
Tires at the time of the picture were 255/50/15 I think..
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 02-28-2008, 07:24 AM   #16
68c10owner
68c10owner's Avatar
yeah I`m a idiot. Thanks,lol.
Front:
Rear:
Thanks,
Anthony
Thanks for the specs. I like the look.
Thanks for the info.
Anthony
Old 02-28-2008, 11:25 AM   #17
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Good-looking 78, Twisted...
Not to go OT, but is the installation of the Procharger complete? If so, got any pics?
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 02-28-2008, 06:32 PM   #18
ton*loc
ton*loc's Avatar
man all those trucks sit so cool !
I'm worried about my headers scraping every if i'm that low. plus mine is a long bed so i wonder if my rear bumped and tow hitch will scrap ?
MMA RECORD 24-5
Old 02-28-2008, 06:44 PM   #19
BowTieOgre
Flip kit, 2" springs and 2.5" spindles here for a 4.5/5 drop. Ive got plenty of room between my axle and the bumpstops. Tires are 275/60/15 all around.
Twisted...that is a FINE looking truck you have there!
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 02-29-2008, 12:24 AM   #20
moneyeater
moneyeater's Avatar
This is my longbed dropped with 2,5" spindles and 2" springs and a flipkit!
She rolls on 10x15 eagle alloys with 265/50 and 295/50 Bfgs!
more pics in my webalbum!
My little US vehicle parts business:
http://www.thegearheaddepot.com/
Come have a look!
´81 GMC C 10, Spanish Red
moneyeater is offline   Reply With Quote
Old 02-29-2008, 01:10 AM   #21
Rc 415
Flat Black, & Chrome!
Rc 415's Avatar
1983 Chevy C10 Stepside Sold
http://s69.photobucket.com/albums/i76/rc_415/
Rc 415 is offline   Reply With Quote
Old 02-29-2008, 04:57 AM   #22
jermasaurus
jermasaurus's Avatar
I have GOT to bring my front end down the extra 2" ASAP! I have the 3" spindles right now. Your trucks look sweet!
79 Jimmy slammed AKA James Down
jermasaurus is offline   Reply With Quote
Old 02-29-2008, 09:44 AM   #23
Twisted78SS
Wide n'Low
Thanks,
Almost complete, working to finish some exhaust before the inital run-in. I want to put some miles on the motor before I run the Procharger. Been a bit side tracked getting my Blazer projects underway. All in good time.. With the weather getting better, I had better get on it!
Air Force Retired
Old 03-03-2008, 11:08 AM   #24
boxrodz
boxrodz's Avatar
Originally Posted by Twisted78SS View Post
Thanks,
Sounds good.
Thanks for the response.
boxRODz
Old 03-03-2008, 10:13 PM   #25
1984 swb chevy
1984 swb chevy's Avatar
Here is my 84 with 5/6 and 20/s
1984 swb chevy is offline   Reply With Quote
