Old 06-07-2024, 08:31 PM   #1
dboboltz
250 air cleaner
All,
I upgraded to a 11" brake booster when adding disc brakes and original air cleaner no longer fits on the monojet single barrel carb. What is best solution? With tighter clearance it seems a 8-9" air cleaner is as large as I can go. The carb has a manual choke so I need to figure out about a 1" rise as well. Any direction would be appreciated.
dboboltz is offline   Reply With Quote
Old 06-07-2024, 09:32 PM   #2
geezer#99
geezer#99's Avatar
Re: 250 air cleaner
Pics here of what you need.
https://67-72chevytrucks.com/vboard/...ht=Air+cleaner
Old 06-07-2024, 09:39 PM   #3
geezer#99
geezer#99's Avatar
Re: 250 air cleaner
Safety concern for you.
Move or eliminate that fuel filter.
They tend to crack and leak. Not a good spot over the exhaust.
Old 06-07-2024, 09:50 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: 250 air cleaner
^ Indeed. I had one of those on my '66 Le Mans that was dripping on the intake manifold exhaust crossover. Crazy. I'm actually considering replacing the fuel filter on my truck with something like the inline filter that the general put between the tank and the fuel pump.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 06-08-2024, 08:19 AM   #5
72c20customcamper
72c20customcamper's Avatar
Re: 250 air cleaner
If you’re not worried about originality try a search on mini air filters found this real quick . And ditch that filter asap they tend to leak .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 06-08-2024, 09:58 AM   #6
dboboltz
Re: 250 air cleaner
This says for a 74 - think it would work? Thanks
https://www.ebay.com/itm/186276174475
Old 06-08-2024, 10:31 AM   #7
geezer#99
geezer#99's Avatar
Re: 250 air cleaner
The right design but not sure on the riser fitting onto the carb.
Might need an adaptor for that.
Old 06-08-2024, 12:44 PM   #8
RichardJ
Re: 250 air cleaner
I wouldn't wish one of those little tiny air cleaners on anyone.
With a Clifford Intake and a 4bbl you need even more room. I used a booster without the bell crank to move the MC farther away from the engine.
I used the original '67 offset air cleaner, but welded on a much larger throat for the Carter AVS and enlarged the passage way across the top, to prevent restriction.
Originally, I kept it as a oil bath, but could never keep it clean. I gutted the inside and converted it to use a paper filter.
That vent tube on the top of your carb is for a Charcoal Canister. Not sure what you have under that tape, but the float bowl needs to be able to breath so you can't close it off completely. I cut the conical center out of a Rochester stone filter and jammed into the vent tube on my Carter. Every couple of years I pull it out and clean it.
I'd rethink that manual choke, cable holder. The original holder would have been similar to this one that Edelbrock sells. It could be trimmed and maybe even a new hole drilled to make it more compact and probably more reliable. It uses one of the carb top screws.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 06-08-2024, 02:59 PM   #9
72SB
Re: 250 air cleaner
I bought this from Speedway for $20, maybe less. Used a longer bolt for the stud as stock was too short. Manual choke. Has a punch out in bottom for breather hose
72SB is offline   Reply With Quote
Old 06-08-2024, 06:54 PM   #10
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: 250 air cleaner
--Richard J -- What carb is that over your Clifford intake? And what headers?
I crossed over into the 4 Barrel camp in 1978, so I can't help the OP's quest for an aftermarket Monojet air cleaner.
Old 06-08-2024, 07:47 PM   #11
Jason Banks
Jason Banks's Avatar
Re: 250 air cleaner
Here's one I have where a previous owner chopped a chunk out and flipped it around(and welded it back in) and then trimmed the top. I cleaned up the work some and have been happy enough with it.
Jason Banks is offline   Reply With Quote
Old 06-10-2024, 09:31 AM   #12
70STOVEBOLT
70STOVEBOLT's Avatar
Re: 250 air cleaner
Yes, that should fit, but the riser may be too tall. There were two different length risers, but I don't recall which one is needed on a 250. The air cleaners may not be the same between a 250 and 292 but are close enough to work with the correct riser..
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 06-27-2024, 01:24 AM   #13
MS66
MS66's Avatar
Re: 250 air cleaner
That's a nice looking engine compartment, almost like it never sees the road , what year is that truck?
BTW, your inbox is full.
MS66 is online now   Reply With Quote
Old 06-27-2024, 02:20 PM   #14
Jason Banks
Re: 250 air cleaner
It is a 1968, daily drove it for about a month over the winter. It's much dirtier than that now, but that photo was right after putting it back together.
Old 06-28-2024, 01:03 PM   #15
54blackhornet
54blackhornet's Avatar
Re: 250 air cleaner
Congratulations that is one awesome looking engine compartment ! The attention to detail is incredible..Jack
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 06-29-2024, 10:30 AM   #16
Jason Banks
Re: 250 air cleaner
I need an updated picture but couldn't find one. Got a longer Positive battery cable so it's not just draped over the inner fender and replaced the 3/4 ton booster and MC with aftermarket.
