11-02-2009, 08:39 PM | #1 |
Leaf Springs on 71 Chevy C-10
I need to replace a few leafs on my 71 Chevy C-10 LWB. A previous owner heated them to lower it and they are rubbing on a bed crosspiece. As I look on parts sites I am finding the leaf springs are the same from 1971 to 1998. Are the leafs interchangeable through this entire range of years?
Thanks for any help! |
11-02-2009, 09:07 PM | #2 |
Re: Leaf Springs on 71 Chevy C-10
i could be wrong (and if i am someone please correct me) but i think 67-72 have 2 1/4 inch wide leafs, while 73 and up were 2 1/2 inches wide.
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
11-02-2009, 09:17 PM | #3 |
RedBaron you are correct. 73 on up will not fit
11-03-2009, 06:41 PM | #4 |
Thanks! I was a bit skeptical considering that was quite the range of years.
11-03-2009, 07:21 PM | #5 |
Why can't he use the 73 and up springs? He could use wider saddles couldn't he?!
11-03-2009, 09:15 PM | #6 |
yes he can use the 73 up springs. you will need the spring perches from 73 up axle. check the FAQ section im sure there is a write up posted there
