Old 01-14-2024, 03:58 PM   #376
Scurry67
Re: 67 SWB First Build
Thanks for the compliments. I did the mod a couple years ago. It wasn’t terribly tough from what I remember. Fit it up how i liked it and then welded the bolts in place and removed the head. Then just some body filler and sanding to make it look smooth. It installed with no bracket modifications. I’m really liking the look, too.
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 01-15-2024, 11:54 AM   #377
kev2809
low n' slo
kev2809's Avatar
oh nice. ya it turned out great..going to have to steal that lol
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 01-18-2024, 07:27 PM   #378
BAD1916
Just read through this build. Looks amazing. Love the color choice
BAD1916 is online now   Reply With Quote
Old 01-19-2024, 02:28 AM   #379
Scurry67
Do it!
I appreciate the compliment. I think the color is going to pop when it gets outside. Hopefully that day isn’t too far down the road
67 SWB First Build
Old 01-19-2024, 09:04 AM   #380
zicc1835
zicc1835's Avatar
Originally Posted by Scurry67 View Post
I set out on a goal this past week to get a handful of parts painted and installed. High build, sand and seal coated the parts by Wednesday.
Attachment 2328238
Shot paint on Thursday. The color is a Toyota color called cement gray. It has a slight pearl to it. Very happy with the contrast in colors
Attachment 2328239
Grill trim, headlight buckets, emblem and front bumper installed. Reinstalling the trim was a total PIA with keeping the fasteners seated. That was definitely a frustrating couple of hours, but it came out nice. I’m really liking the look
Attachment 2328240
Next goal is to get the doors put together.
one of my favorite build threads great progress ....I actually bit my lip putting the fasteners on the hoops was a PIA...
zicc1835 is offline   Reply With Quote
Old 01-27-2024, 02:06 PM   #381
Scurry67
I appreciate the compliment. I was surprised at how long that install took. It definitely tested my patience, too!
67 SWB First Build
Old 01-27-2024, 02:24 PM   #382
Scurry67
Reassembly continued…
I spent a few evenings prepping and painting misc interior pieces. Then another few nights installing the freshly painted pieces.
The glove box door turned out okay. It has its flaws, but overall I’m happy with it!
Reinstalling the door guts was more time consuming than i thought it would be. I also need to clean the window glass still. The Altman door latches work terrific ! I’ll jump onto the driver door reassembly over the next week.
67 SWB First Build
Old 02-07-2024, 02:06 AM   #383
Scurry67
Small updates. I’ve been very focused on getting as much of the interior put together as possible. It definitely makes for easy satisfaction! AC ducting mostly installed. Waiting on adapters for the reproduction defrost vents. I also got to installing more door pieces.
I currently have the precision door seals on. Even after all the threads i read about difficulty shutting the door, I thought mine would be different lol. Needless to say, I have new Honda seals ordered and on their way. Hopefully they work as good as everyone says they do!
In the meantime while waiting for some parts, I’m taking a run at re-doing my seat upholstery. After some minor seat frame repair, i took the frame to the blaster and I’ve started diving into the foam repair.
67 SWB First Build
Old 03-03-2024, 06:06 PM   #384
Scurry67
Interior progress continued over the last few weeks
Spent some time fitting the foam. It wasn’t terrible other than the big mess it makes. I also shot the seat frame with some black paint i had laying around. It turned out great. Lastly, I had to replace the broken pull cable for the seat adjuster. A quick trip to home depot took care of that.
I also was able to install more interior pieces. The interior door arm rest and the headliner went in smooth. I ended up using adhesive tape for the headliner. We’ll see how that goes.
Seat belts showed up yesterday, so i through those in. My seat cover is on order and should show up this month!
67 SWB First Build
Old 03-04-2024, 12:53 AM   #385
1972CheyenneSuper
1972CheyenneSuper's Avatar
Progress looking great!! It's definitely a lot of work, but it's paying off tenfold. I'll be following the rest of your journey.
Any tips for putting the door interiors together that isn't covered in the videos and guides?
1972CheyenneSuper is offline   Reply With Quote
Old 03-04-2024, 10:18 AM   #386
loudchevy
Active Member
loudchevy's Avatar
Nice repair on the seat foam and seat adjustment cable.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 03-04-2024, 05:37 PM   #387
zicc1835
zicc1835's Avatar
color combo in the cab is awesome can't wait to see the seat cover you picked
Old 03-05-2024, 01:27 AM   #388
Scurry67
Much appreciated. It definitely is a lot of work, but i feel like there is a light at the end of the tunnel!
I found a really good video on youtube that went through it pretty thoroughly, plus it was straight to the point which was nice. I disassembled the doors years ago so it definitely saved me time from the guessing game.
https://youtu.be/Zay64xBOgD8?si=mTnr2gc9TBux4cJE
67 SWB First Build
Old 03-05-2024, 01:30 AM   #389
Scurry67
Thanks for the compliment. Fingers crossed the foam holds up and is comfortable!
67 SWB First Build
Old 03-05-2024, 01:37 AM   #390
Scurry67
I really appreciate it. I’m really liking it as well. It’s definitely coming together. It definitely helps checking out the other threads on here, like yours, to keep the inspiration up!
My son seems to approve, too!
67 SWB First Build
Old 03-07-2024, 11:03 AM   #391
1972CheyenneSuper
That is a pretty good video, thanks!
Old 03-07-2024, 01:47 PM   #392
KyleSeal
KyleSeal's Avatar
What tilt column is that? Looks kind of like the CPP one?
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 03-07-2024, 04:52 PM   #393
Scurry67
It’s actually a refurbished tilt column. I had it sent out to a member here on the board years ago to be redone.
67 SWB First Build
Old 04-06-2024, 12:32 AM   #394
Scurry67
Update.
Been spending the last month verifying tolerances on my engine. Made some decent progress with getting the pistons installed. Hope to get the cam installed in the next week. It has been a fun learning experience for sure.
Last night I jumped into the reupholstery on my seat. It wasn’t too hard at all and turned out great. The repaired side feels awesome and you’d never know it was repaired.
67 SWB First Build
Old 04-06-2024, 09:15 PM   #395
1972CheyenneSuper
I like the seat color, really nice complement to the body color.
Old 04-06-2024, 09:28 PM   #396
zicc1835
zicc1835's Avatar
Originally Posted by 1972cheyennesuper View Post
i like the seat color, really nice complement to the body color.
x2
Old 04-09-2024, 11:02 AM   #397
Scurry67
x2
Thanks! I’m really happy with it so far. It seems to be good quality and comfortable. Happy to check that off the list.
67 SWB First Build
Old 04-14-2024, 06:17 PM   #398
Scurry67
Weekend update. Waiting on parts for the engine. I went ahead and got the back window installed with my brother. I had to laugh at the stickers they’ll be coming off eventually.
It took lots of soapy water and had a small minor tear on the interior corner but it looks good. The tear isn’t too big and should go unnoticed.
67 SWB First Build
Old 04-22-2024, 10:50 PM   #399
Scurry67
Road block on the engine. The camshaft that came with the 383 kit is having issues clearing the piston rods. After researching it, it sounds like I’ll have to either clearance the piston rod bolts or get a small circle base cam. Disassembling the pistons isn’t sounding very appealing….
In the mean time, while i ponder that decision, I’ll just admire how far the truck has come.
67 SWB First Build
Old 04-22-2024, 11:19 PM   #400
Getter-Done
Getter-Done's Avatar
There is a Lot of clearance things that need to be done for the 383 Thing.
Cam and connecting rod bolts is the main thing.
Some of the Crankshafts need a little work also.
84 Chevy K-20
