Old 12-04-2008, 07:59 PM   #1
stump
87 to 73 front end swap?
i know its possible have read about it, i would need differmt hood,fenders,inner fenders, radiator support, and what els? i found a used 3/4 ton that is being parted will that 3/4 ton work with my 87 c10? the 3/4 ton is 4x4 to.. thanks for any help.
stump is offline   Reply With Quote
Old 12-04-2008, 08:02 PM   #2
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
Re: 87 to 73 front end swap?
I was looking into for my self. Your gonna need just about everything for the front. And for the hood hinges, you have to mod the fire wall for the hinges.
But the swap looks bad azz!!
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 12-04-2008, 08:36 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
putting a 73 front in on a 81-87 is a piece of cake. If you have a donor unbolt EVERYTHING that attaches to the 73 and bolt it on your 87.
You WILL need the COMPLETE wiper assembly that is bolted to the 73 cowl though and will need to "fix"/drill holes in the 87.
You will also have to fix the bumper mounts at the frame horn. (and get the 73 bumper.
4x4 doesn't matter, it is the sheetmetal you want and it is the same.
If you want it looking "correct" weld a cover over the 81-87 hinge hole. Not required though.
You do not need to modify the firewall for hinges to put a 73 front end on an 87, the 73 hinges bolt to the fenders.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
