02-10-2009, 09:55 AM | #1 |
Active Member
WIW Double hump heads
No history on these, removed from a '70 parts blazer, casting# 3917291 & 3890462, does $300 pr sound fair? Too heavy to ship, but could deliver to spring Carlisle PA swap meet.
02-10-2009, 10:10 AM | #2 |
Active Member
Re: WIW Double hump heads
I don't think Blazers ever had double hump, 2.02 heads did they? I thought they were only on Corvettes, Camaros, Chevelles? $250-$300 sounds about right for the original folks.
1972 K5 Blazer ALL ORIGINAL paint & engine, A/C, Tilt, 4sp, AM/FM, Tow Hooks, Aux Battery Tray, Tach, Vacuum 2004 FORD FX4 SuperCrew 2005 CTS-V 12 sec family car 2008 Buick Enclave AWD, Nav, & DVD, Wife LOVES it! |
02-10-2009, 10:46 AM | #3 |
I found a 327 with the double humps in a 69 pickup that i bought. As far as I can tell the motor and power glide tranny was original.
02-10-2009, 11:43 AM | #4 |
Gone Fishing
250-300 should be goin rate
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
02-10-2009, 11:53 AM | #5 |
Active Member
This was definitely not the original blazer engine, just installed in it.
More pics. |
02-10-2009, 03:08 PM | #6 |
i got a complete 327 with a powerglide out of a old caprice cop car came with dbl hump heads
2009 dodge hemi custom paint 86 lwb bagged layin frame 73 2 door nova 54 bel air |
02-10-2009, 03:17 PM | #7 |
Hey, what is the date code on them ? Thanks,buddy
02-10-2009, 05:23 PM | #8 |
Gone Fishing
3890462....66-67...302/327/350..Camel hump,no accessory holes,64cc chamber
02-10-2009, 05:24 PM | #9 |
Gone Fishing
3917291....67-68...302/327/350..Camel hump,no accessory holes,64cc chamber
02-10-2009, 05:24 PM | #10 |
Gone Fishing
Those notes are from Mortec
02-10-2009, 06:00 PM | #11 |
The one has a date code of B227 which is Feb. 22, 1967 also someone has gone though these orig. these heads came with press in rocker studs yours are screw in w/ push rod guides and the springs aren't stock either I bet they've been ported as well I have a stock set of 462's and the machine work alone runs $500 most people now days are going with vortec's but if someone were restoring a camaro or corvette and wanted to keep the numbers they would be worth quite a bit that's mho
02-10-2009, 07:30 PM | #12 |
what makes these double hump heads Im curious
02-10-2009, 07:37 PM | #13 |
Roadtrip!
Look at the casting on the end of the head. There are a couple good pics of it.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
02-10-2009, 08:45 PM | #14 | |
they did come with screw in studes if they were factory equipped with guideplates. I have some 461's with factory screw in studs and guideplates, and my 291's from my 302 have factory guideplates as well. |
02-10-2009, 09:37 PM | #15 |
this is a mismatched set of heads,ie both heads should be 461 or 291 to be a matched set and should have very close casting dates.461 with 1.94 and 1.5 valves came on 275 and 300 hp 327 and some 67-69 350 .some came with 202 and 1.6 valves 3/8s studs and guide plates on 325 ,350,360 and 370hp engines 461x are corvette 370hp and have larger volume runners 291 also came in several combinations all 67 and 68 302 z28s had 291 with the lager valves and studs and guide plates 69 and 70 z28s carry 186 casting #s
02-11-2009, 11:46 AM | #16 |
thanks I will have to check my heads to see if they are double hump I was told the were expensive but I am just learning about my engine and how to work on it so any info is helpful. plus I am learning to weld so I can fix my blazer
