06-17-2009, 02:14 PM | #1 |
1969 Custom 30 wrecker
Squeaking poly cab mounts
I went with the poly type cab mounts and at first they were fine but now I'm getting alot of squeaking. I just tried snugging them up but it didn't help.
Any tricks to fixing the squeak? Thanks, Bob
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
06-17-2009, 02:17 PM | #2 |
Re: Squeaking poly cab mounts
There is a special grease that should always be used with poly bushings. You'll need to pick some up, pull the bushings apart and lube 'em up!!
I may be doing the same thing in the near future... I hope I don't end up with squeaks. |
06-17-2009, 02:27 PM | #3 |
Formerly- 1972SuperCheyenne
I had the same issue on a truck I used to have. I had to lube them every couple months. I just switched them out for the factory rubber stuff.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
06-17-2009, 03:05 PM | #4 |
Do you have the red or the black ones? Supposedly the black ones have graphite in them to help reduce the squeaking. You can do what I do for noises like that, just turn the radio up a little louder, .
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-17-2009, 04:10 PM | #5 |
Replace with factory-type rubber.Poly mounts like to squeek.
06-17-2009, 04:20 PM | #6 |
Project Junkie! Fishing Poor!!
Weld the body to the frame... Just kidding. The only real way to stop the sqeeking perminently is to go back to rubber. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
06-17-2009, 04:26 PM | #7 |
I have always heard powder graphite, so dust and dirt doesn't stick to it like penetrating oil, or petroleum jelly.
06-17-2009, 04:56 PM | #8 |
These are black. Going back to rubber is not what I want to hear, I bought another set already to put in on my other truck.
Thanks, Bob
06-17-2009, 04:59 PM | #9 |
So is the conventional wisdom to use poly for everything but the cab mounts, and use rubber for those, or are there other places that rubber should be used?
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
06-17-2009, 07:09 PM | #10 |
1972 C/20
I have heard that in general Polyurethane will squeak. Also from personal experience on my honda civic. I replaced all of he front end rubber with with poly and now it sounds like the car is a POS when driving over bumping surfaces. I think I will opt for rubber from now on.
06-17-2009, 07:58 PM | #11 |
Polyurethane is bad for body mounts, and engine mounts. They defeat the purpose that the manufacturer used the rubber for. Rubber mediates movement, and vibrations. Polyurethane does not do this, at least not effectively. The chassis on these trucks are "C" channel chassis, designed to flex and move with the conditions of the road. (This is why they are bolted and riveted together. Bolts and rivets allow for flexibility) Unlike the bodies and their parts witch are spot welded together and can not move like or with the chassis. This is why GM used rubber mounts and did not bolt the bodies directly to the frame. The flexibility of the rubber is needed to preserve the body by absorbing at least most of the movements that the chassis does under normal circumstances. Same goes for the engine, it torques, flexes and vibrates, so it is mounted on rubber mounts so the vibrations and movements are not translated throughout the vehicle. Causing problems in the chassis and body. The long and short of my point is poly is good for suspension, but that is all. It is good for suspension because it tightens it up so the vehicle handles better. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys Last edited by Classic Heartbeat; 06-17-2009 at 07:59 PM. |
06-17-2009, 08:40 PM | #12 |
thats why they are a little cheaper..
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
06-18-2009, 06:24 AM | #13 |
Actually, they were the same price. Since I'm keeping my trucks for life and drive them all the time, I opted for the poly for durability.
After seeing how long my "repop" fuel filler neck grommet lasted, I just couldn't make myself try repop body cushions. I just invisioned all those cracks!
06-18-2009, 07:26 AM | #14 |
Rubber lasts a very very long time.There are plenty of trucks with original 40 year old oEM mounts.There are no 40 year old poly mounts.
The question I always asked is why would someone want to stiffen what needs to give?Urethane bushings were created to firm up suspension,then they expanded into all bushings when they caught on.Look at the stresses on suspension bushings compared to body.The suspension wants to stay put while the rest of the truck wants to go where the forces of physics is taking it...just about the whole truck.The body is bolted rigid to the frame and intended to stay that way...together.But,bushings are used to allow some give to absorb vibration as well as take stresses off of lighter sheet metal versus heavier steel chassis.I have a rigid-mount Harley and the bike is constantly trying to fall apart.Bolts always backing off and lighter metal is always splitting.My feet try to vibrate off the footboards,mirrors are useless,and hands get vibrated.the seat helps,but the butt can get numb,too.The newer rubber-mounts have none of these characteristics. I guess there have been improvements made to urethane.But,I had a wandering problem with a`71 K/20.After replacing every part involved in the steering it was still all over the place.I had someone work the wheel while I watched underneath.The whole assembly of springs and axle were racking back and forth.The 3 year old poly lift kit bushings were all cracked up.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 06-18-2009 at 07:29 AM. |
06-18-2009, 07:46 AM | #15 |
Geeeee...I am sure glad WES sold me rubber bushings. The bushings that was taken off my 70cst were the original bushings...at least that is what I was told. The only squeak I want to hear is one from a mouse.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 06-18-2009 at 10:23 AM. |
06-18-2009, 08:53 AM | #16 |
Now I'm confused. Should I plan to put rubber everywhere, or rubber in the cab/engine mounts and poly in the suspension parts?
06-18-2009, 08:59 AM | #17 | |
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 06-18-2009 at 09:00 AM. |
06-18-2009, 09:00 AM | #18 |
Active Member
Go to Lowes or Home Depot and get some plumbers silicone grease, looks like the same stuff sent with some poly kits only cheaper. You'll have to disassemble the mounts and put wherever the poly touches the metal. Don't know how long it will last but should take care of the squeak.
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin |
06-18-2009, 10:55 AM | #19 |
Moderator
The rubber used nowadays is nowhere near the quality of the rubber manufactured 40 yrs ago. The fuel filler gaskets are a good example of this. I would also guess that this would hold true with any rubber piece made today, including the cab mounts. I am thinking that it has something to do with EPA regulations....no wait, they are made in taiwan now...ok, that explains it! Even so, I would still opt to use rubber for the cab mounts simply because they will not squeak and will give you a smoother ride.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 06-18-2009 at 10:57 AM. |
06-18-2009, 11:12 AM | #20 |
Silly as it may sound I brush Anti-seize on Poly bushings/ mounts before I install them.. Seems to work... I agree that rubber is the best way to go.. Yes poly is better for suspension but always seems to start to squeak... For a street car/truck and not a track car/truck go rubber... And if you want to hear noisy meet up with me and I will take you for a ride in a track prepped BMW M3 with solid aluminum bushings! Now thats noisy!
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
06-18-2009, 12:18 PM | #21 | ||||
Secondly, fuel filler grommets are exposed to the weather degrading them a lot quicker (UV rays are bad on everything) The body mounts are only exposed to water and dirt, so they will not degrade nearly as fast. Quote:
Any anti-seize or grease will ware away and have to be reapplied time and time again. Rubber bushings are installed and forgotten for many years to come. WES
06-18-2009, 01:40 PM | #22 | |
