10-16-2009, 11:06 AM | #1 |
whining noise
I just put in a 338stroker, it makes a whining noise that gets louder when Im coasting and slowly goes away as I accelarate, Im wondering if the converter is to tight and I need a higher stall, Its got a th350 with stock stall
Hei, long tube headers, ededl eps intake, 1406 carb, any thoughts, thank you, |
10-16-2009, 12:14 PM | #2 |
Re: whining noise
Your description of the whining makes me think rear axle ring & pinion, noisy coast and quieter under load. Also maybe a planetary gearset in the trans??
I'd have to hear it to really say. Does it change with RPM or MPH? Is it present in all 3 speeds?
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
10-16-2009, 05:04 PM | #3 |
Re: whining noise
ya it does change with rpm, just put new gears in but it did it before the new gears, it sound like its right under the floorboard,
10-16-2009, 09:05 PM | #4 |
Re: whining noise
Maybe your inspection cover on the transmission might be rubbing on the flex plate?
10-16-2009, 10:29 PM | #5 |
Re: whining noise
Is it at the rear of the truck or at front? Could be Alternator ?
10-16-2009, 10:32 PM | #6 |
Re: whining noise
Didn't read all post disregard. sorry.
10-17-2009, 07:56 AM | #7 |
Re: whining noise
Ive checked out the trans cover but I havent checked the alt. , I gotta work today but I will look into the alt tommorow, but Im pretty sure its comming from the front of the tranny, I appreciate the help, keep the responsed comming
10-17-2009, 08:30 AM | #8 |
Re: whining noise
I thought I had the same problem,but the whining stopped and now she`s in Florida...
I`d think you`d definitely want a higher stall.I`ve heard what you describe and think it is in the converter.
