Old 11-18-2002, 12:26 PM   #1
landon4421
Life is Good !
landon4421's Avatar
Electrical Question !
OK here gose, My wife 1971 chevy, No dash lights. All the other lights on the truck work. But the dash lights have not worked in two weeks. When I'm driving at night I noticed the left turn signal light was on but it is dem, and the turn signal is not on. Has anyone ever had these problems before, how do I fix it ?? I'm stummped !!
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 11-18-2002, 01:10 PM   #2
blue_69
someday
blue_69's Avatar
the turn signal light in the dash will do that when you have a bulb out it could be as simple as the bulb or a bad ground. The das lights on the other hand i cant recall exactly where they get power from or where they are grounded i would check the fuses first and you may have to pull the dash out and see if you have power there or not. wiggle the light switch maybe you have a bad connection in the dash dimmer.
Click Here to search ebay for all 67-72 parts
My 72 CST blazer build
72 CST Blazer 4x4
67 2wd swb ( project onion crate )
86 4x4 lwb plow truck
40 x 60 foot barn to work on all this stuff
blue_69 is offline   Reply With Quote
Old 11-18-2002, 02:19 PM   #3
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
green wire from light switch is panel lights, wire goes to fuse box, thru fuse, then out on grey wire to dash lights. Check your ground, and turn light knob, contacts on rheostat at switch may be bad, or fuse could be out.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
Old 11-18-2002, 03:05 PM   #4
busterwivell
You said other lights work, even the tail lights? When my buddies dash lights went out, so did the tail lights and it was because one of the wires for the taillights grounded on the frame.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 11-18-2002, 05:34 PM   #5
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
tail, park and dash lights all are on separate circuits from the light switch, and use separate fuses after the switch, unless someone has kludged them together, but then you would get no dimming of dash lights. Parking is separate on some, meaning that front park lights do not work when headlights are on, usually 66 and earlier.
Old 11-18-2002, 06:27 PM   #6
frisky68
I just had the identical thing happen w/ my 69....no dash lights, but all other lights would work....even had the left turn signal on full time....my problem was that i had no power @ the instrument lamp fuse in the fuse block....i pulled the fuse block off and checked the wiring there, but all appeared ok...did spray some electrical cleaner on both sides of the fuse block...still havent found what is causing the proble...so until i do...i ran a jumper wire from an ignition position on the fuse block, through an inline fuseholder and clipped the other side to the terminal for the instrumentation on the fuse block...means i have dash lights as long as the ignition is on, but its better than not having any at all....let me know if you ever do find the root cause of your problem...sure sounds like we are having identical problems though.
94 K1500 SWB w/ 4" body and suspension lift
frisky68 is offline   Reply With Quote
Old 11-18-2002, 07:15 PM   #7
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
No dash lights and a turn signal lit up when the lights should be on indicates a bad ground to me. Wiggle the plug on the back of the instrument panel. If that doesn't work, remove the IP and check the harness and contacts at the plug. The black wires should be ground when checked with a ohmmeter.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 11-18-2002, 11:15 PM   #8
Hooter
My other Love
Hooter's Avatar
There is a wire on the bottom right hand corner of the guage cluster. This wire is a ground strap and goes to the metal dash.
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 11-19-2002, 04:03 PM   #9
frisky68
Problem solved !!!!!!!!!!!!!!!!!!!!!!!!
Mine ended up being a ground issue as mentioned above...I ran a ground wire from the engine (i used an open hole on the passenger side head) to the frame....then I ran a ground wire from the frame to the body(mounted on the bolt used to mount the master cylinder..just double nutted this)...and low and behold I have dash lights and my left turn signal no longer stays lit up..I dont have a ground wire running from the back of the guages to the dash though...but it doesnt seem to need it.
