Old 08-06-2011, 12:53 PM   #1
darkone
Holy Great Breaks in the Back Batman! WTH did I Get Myself Into? c20 rear drums help
Hey all, im tearing open my rear drums today to clean them out from a sandblasting. but..... now theres fluid spewing out, and a rod bigger than anything i imagined sitting on the ground and im not sure what im getting myself into. here are a few pics. Does anyone have a play by play i can use for these drums to tear down and re-assemble? looks like im going to have to do something to replace some fluid, etc. should i call a pro?
darkone is offline   Reply With Quote
Old 08-06-2011, 03:42 PM   #2
darkone
Re: Holy Great Breaks in the Back Batman! WTH did I Get Myself Into? c20 rear drums h
i called napa today for a hub seal or gasket or whatever, and they said they have a 3.8 and a 3.9 diameter from outside to outside..... but im not finding any measure that comes up with 3.anything on the area of the hubs. can anyone point me in a btter direction as to what im measuring for a hub seal?
Old 08-06-2011, 03:43 PM   #3
Mike C
Mike C's Avatar
Don't you have a simple repair book? That rod is the axle. The drum is held on with a double jam nut setup like a front 4x4. Diff oil moves from the center to the ends to lubricate stuff. When you are done, just top off the rear diff.
But the first thing is go buy a $25 service manual and read it. Then start working.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-06-2011, 04:18 PM   #4
Sinister
Between Trucks...
Sinister's Avatar
Here's a link to the socket to get the drum off: http://www.google.com/search?hl=&q=K...US414&ie=UTF-8
Try putting the bottom axle bolts back in and a rag stuffed into the tube to stop the flow of oil. It's a messy job for sure. I looked up the parts on Napa website online and brought the part numbers in when I did mine. The Factory Service Manual is a big help for this.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
