5 lug conversion 5 on 4 3/4
does anyone know of a kit like this. i have lots of car wheels .i would love to use on my 69 rat project. thanks for your help
Re: 5 lug conversion 5 on 4 3/4
its good to see that someone else is wanting to do this... i had my front (5 on 5 rotors)
drilled for 5 on 4 3/4. plan to use a trans am rear end.
#3 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
ECI Hot Rod Brakes makes a bracket that will bolt to your "drum brake" spindle. This only works with the 68-72 Chevelle rotors, which have the 5x4.75 bolt pattern. You can find them here: http://ecihotrodbrakes.com/ The other option is to use the disc brake spindles for the 71-87 trucks,... and buy the "conversion rotors" from POL. Look here: www.PerformanceOnLine.com.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-04-2010 at 10:57 AM. |
