Old 12-18-2006, 04:29 PM   #1
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
How low should i go???
Hey guys, im getting ready to put my 83 a little closer to the ground. My question is how low should i go? I definitly want it to be noticably lower, but i do NOT wasnt it so low i cant load it on a trailer when i go to and from the drag track. I also would like to keep similar sized wheels/tires on it for now (275/60R15 on 15x8 wheels) Im thinking no more than a 2/4 or a 3/5. Let me have your guys input. Heres some pictures of it for pondering.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 12-18-2006, 04:36 PM   #2
AesC10s
Chevy truck addict
AesC10s's Avatar
Re: How low should i go???
Bag It!!!
AesC10s is offline   Reply With Quote
Old 12-18-2006, 04:54 PM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I don't know how much clearance you need to get it on the trailer, but this is what mine looks like lowered 2.5/4 with spindles/drop leaves. It still has about the clearance of a car. It never scrapes on speed bumps or going in and out of parking lots. I am running 255/70/15 tires on 8 inch rally wheels.
http://www.slonaker.net/gallery/albu...cs/c10_low.jpg
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 12-18-2006, 05:16 PM   #4
Blackstone
Blackstone's Avatar
I'd 3/4 it for sure. Noticably lower, but practical ride height.
Blackstone is offline   Reply With Quote
Old 12-18-2006, 05:20 PM   #5
beaterC10
I have a 3/5 daily driver. Only things I have to watch are curbs when parking and deep ruts/chuckholes. I would suggest going with 2.5 spindles instead of 3 spindles though, I had to swap out my 8" ralleys for 6.5" on the front to get clearance with the a-arms.
beaterC10 is offline   Reply With Quote
Old 12-18-2006, 05:55 PM   #6
hiway
Mad Scientist
3/4
Everythang relates to Beer!
86 1/2ton on tons! sbc/465/208/D60/14/35's
81 Postal....with 468 bbc
97 Merc Marq comuter
07 Suburban
02 Danger Ranger
hiway is offline   Reply With Quote
Old 12-18-2006, 07:40 PM   #7
82c10
needin' money
5-7
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 12-18-2006, 08:07 PM   #8
ProStreet83C10
Drag Racer
Originally Posted by 82c10 View Post
5-7
no...
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 12-18-2006, 08:08 PM   #9
ProStreet83C10
Drag Racer
so basically do a 2.5-3/4
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 12-18-2006, 08:29 PM   #10
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Assuming you have 255/60/R15 tires like I do.....2.5/4 is perfect. Spindals and hanger shackel combo for the rear. Any lower on the front you have trouble. Replace the coils when you drop it. New coils will help keep the front tire from rubbing on the fender. I would use a grinder and trim the inside of the fender too.
Take a look at the pictures in my signature. The front tires are 235/60R15 and the rears are 255/60R15. The front tires rub because of worn coils. Now I run 245/60/R15 in the front.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 12-18-2006, 08:37 PM   #11
beaterC10
I would go with a 5 drop in the rear using a flip kit. It's cheaper than drop leaf springs, you keep the stock load capacity, and it's probably less work than shackles and hangers. The potential downside of a flip kit is the chance the bolts are frozen up in the spring eyes. They can be a real pain in the XXX to remove when they rust solid in the sleeves.
Just my $.02
Old 12-18-2006, 10:21 PM   #12
piecesparts
Parts and more parts
piecesparts's Avatar
How low is depended on a few things. 1) how much can you spend? 2) How fancy do you wnat to go? 3) How fast do you want to drive? The amount of clearance is important in the last thing.
piecesparts is offline   Reply With Quote
Old 12-19-2006, 02:09 AM   #13
Malo83
Cruzzzn' Vet
Malo83's Avatar
Running a 4/5 drop on my 83 with 275/50/15's on 15x9 rims and love it just remember when you drop your ride your driving habits will have to change to Low and Slow
Malo83 is offline   Reply With Quote
Old 12-19-2006, 04:16 AM   #14
ProStreet83C10
Drag Racer
as far as how fast do i wanna go......my long term goal is put a supercharged big block in it with around 800 or more hp
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 12-19-2006, 04:36 AM   #15
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Yeah, Low and Fast ...
Here's a few 'chops of a straight 2" drop (all around), a 3" drop and a >> 4" drop << to keep some rake. If you get the right bs on the wheels, you may be able to go lower to tuck some wheel. (BTW, I've seen some guys use '2 bys' spacing on their trailer to load their vehicle on the trailer and actually use '2 bys' under the wheels to raise their vehicle so that the door will open when sitting on the trailer.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 12-19-2006, 12:13 PM   #16
AesC10s
Chevy truck addict
AesC10s's Avatar
So NOT true. i had a 72 that the front xmember was about 3 inches off the ground and i did 130+ MPH in it on the highway MANY times with no Problems.
Old 12-19-2006, 02:07 PM   #17
ProStreet83C10
Drag Racer
i like the whole 3" look of it, and it looks like its not enough to mess up the underbody going on a trailer
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
Old 12-19-2006, 02:23 PM   #18
Slonaker
Slonaker's Avatar
The highway is the only place you don't have to be careful.
Slonaker
Stock '01 Silverado
Old 12-19-2006, 03:48 PM   #19
75silverstep
KEEP ON TRUCKIN.
75silverstep's Avatar
Not baggon on you but you take off the front window visor and you might take off 3/100ths and get into the 14ns........5/7 drop the drag strip is nice and flat..haha
1975 C-10 STEPSIDE (ALMOST DONE AGAIN)90 percent done wheres that other 10 haha .1994 GMC Z71 .
75silverstep is offline   Reply With Quote
Old 12-19-2006, 04:10 PM   #20
bodydropped
theres a guy in houston or some were aroun there with a lwb chevy with a 7/9 drop and he drives on and off a trailer without any problems. he did alot of work to get ther frt that low but it had a 496 in it that was badazz and he was tukin some mean tires in the rear i think he was runnin 15x15s in the rear ill try and find pics and it was all drop no air at all on this truck
bodydropped is offline   Reply With Quote
Old 12-19-2006, 06:01 PM   #21
piecesparts
My 84 is not a ground scraper and I don't run bags, but I run the high speeds with the best of them. I have actually seen the speedo buried in the "OH WOW" section of the gauge. I only have a top displayed number of 85 MPH. I have Bell Tech components with a 4/4 drop and running 15X9 rims and 245/60/15s up front and 295/50/15s on the back. Low and Slow is only an attitude not a way of life.
Old 12-19-2006, 06:40 PM   #22
piecesparts
Agree , the visor is not my thing either.
This is my Son's truck
Old 12-19-2006, 06:52 PM   #23
AesC10s
Chevy truck addict
AesC10s's Avatar
piecesparts That is a sharp truck!!
Old 12-19-2006, 09:52 PM   #24
piecesparts
Thanks, we built it with the parts left over from my 84 GMC.
Old 12-19-2006, 10:10 PM   #25
gchemist
gchemist's Avatar
Yea, right. Hell I drive mine faster and meaner.
