Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Engine and Drivetrain
Old 11-21-2016, 01:35 AM   #1
KyleSeal
KyleSeal's Avatar
Building an engine with some storage questions
I was making a mountain of Chevy 350 parts in my house for a while now and decided to go ahead and use them and build my motor, or atleast the bottom end. Well now the bottom end is done (need some cylinder heads) and have the motor bagged, my question is, is it okay to store this motor with just the bottom end done for a little while I look for heads? I used thick assembly lube from CRC and Lunati, will this still be okay in a few weeks for start up or even a month?
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline
Old 11-21-2016, 02:05 AM   #2
B. W.
B. W.'s Avatar
Re: Building an engine with some storage questions
Yes, it will be fine. I've built motors & stored them for extended periods, just keep it clean & dry. (keep the cylinders oiled)
B. W. is offline
Old 11-21-2016, 10:16 AM   #3
coreyjhen
If you used good assembly lube and lubed the cylinders well, you should be able to store it almost indefinitely. Put a few desiccant bags in the bag and suck out as much air as you can with a vacuum cleaner before you seal it up.
coreyjhen is offline
Old 11-21-2016, 12:47 PM   #4
demian5
demian5's Avatar
I had a motor built for a friend for his 64 impala ss by a reputable machine shop.
11 years later I bought the impala with the rebuilt motor still on the engine stand (wrapped in a bag).
I pulled the pan just to make sure it looked ok to run, it looked like the day it was put together.
11 years after rebuild, put it in, runs *****en to this day. However, I think I have a head gasket that is marginal so my recommendation is to install a quality set of head gaskets.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline
Old 11-21-2016, 04:44 PM   #5
KyleSeal
KyleSeal's Avatar
I have the cylinder walls coated in an engine oil, normal 10w-30, and I saturated the pistons in it (with rings on) before install. I figured it would be fine but wanted to double check.
KyleSeal is offline
Old 11-21-2016, 06:07 PM   #6
demian5
demian5's Avatar
Fogging oil works wonders. Look into it.
1986 C20 Scottsdale
Instagram: C10sofOC
demian5 is offline
Old 11-22-2016, 12:37 AM   #7
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
That's what I did on advice. I ran some stabilizer through it, shot the carb with fogging oil multiple times start/stop. Pulled the plugs and shot the cylinders, about 3 seconds each I believe per instructions.
B.W. mentioned keeping it dry. All the hoses are disconnected. Anything else recommended? Perhaps another shot of oil in the cylinders every 6 months or so?
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 11-22-2016, 09:17 AM   #8
coreyjhen
You could put dessicant spark plugs in it to keep the cylinders really dry. They're expensive, like $8-10 each, but that's what aircraft mechanics do when they are storing an engine long-term. Plug-Dri is one brand.
Old 11-22-2016, 01:42 PM   #9
davepl
davepl's Avatar
I would soak a rag in transmission oil and wipe down every machined surface. WD40, fogging, all of that helps, but a consistent coat of oil on the walls and other surfaces is a good idea.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline
350, assembly, build, motor
